Author Topic: Help - Need help identifying a part number for this compression washer?  (Read 7150 times)
Offline Mike Phillips
I was able to get the right bearing and seal at NAPA for my Dana 60 frontend but they couldn't find a part number for the compression washer.
Here's what I'm working on, front axles for a Dana 60
Here's the bearing and seal kit I bought at NAPA
Here's the part I need a part number for...
Offline thirsty
    • Suitor's Garage
Re: Help - Need help identifying a part number for this compression washer?
« Reply #1 on: September 24, 2011, 12:05:22 pm »
That looks like a flat washer/spacer. You can't reuse it Mike?
« Reply #2 on: September 24, 2011, 12:30:52 pm »
I could but I've been replacing everything with new parts just to do the job right the first time.
I shows signs of wear I can take a better picture later...
Trying to get both the frontend and rearend all re-assembled this weekend.
« Reply #3 on: September 24, 2011, 09:09:24 pm »
     Mike, I just went through this, Dan the man at my local Oreilly's hooked me up.  It is called a pre-load washer for the spindle bearing kit, I had to contact my local gm parts guy at a dealership and have him look ( they really don't like to have to do any work ) in the computer for a diagram of the axle breakdown, he could order for me, so I turned it over the the friend who's truck I was working on and he got it.
    Hope this helps, but that is the only place I could find it.
« Reply #4 on: September 25, 2011, 06:47:45 am »
Thanks for chiming in... around me I have Autozone, Advanced, Bennett and NAPA parts stores so I print out this thread and then swing by and see if any of them can help out.
Thanks!
Mike
« Reply #5 on: September 25, 2011, 08:56:37 am »
***Success**
Kevin at my local NAPA knew of a Dana website where he could look up the part number and then order it from Spicer.
 ;D
Offline thirsty
    • Suitor's Garage
« Reply #6 on: September 25, 2011, 09:23:09 am »
***Success**
 ;D
Good deal!
Sounds like it would be a good addition to the parts numbers thread or section if it happens.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=21676.0
« Reply #7 on: September 25, 2011, 02:40:21 pm »
Quote from: thirsty
Good deal!
I take a picture of the packaging, part number and part and added to the parts number thread.
