Author Topic: loading up  (Read 3254 times)
Offline cruisinc10
loading up
« on: September 24, 2011, 01:08:28 pm »
hey guys, need a second opinion. Last night I went playing in some mud in my 84 k10. After that the truck started spitin and sputering under a load. I got up early this mornin and the same issue, my guess is that i got the distributor wet. It idles fine and rev`s up fine in park.~ thanks Mike
1986 C10 355Ci/TH350/2 inch drop/275/60/15 cooper cobra Tires/flat black w/pinstriping- sold
1984 K10 Silverado 305Ci/Th350/6 inch all spring lift/33/12.5/15 interco Trxus MT Tires/factory red and white-Daily Driver
Re: loading up
« Reply #1 on: September 24, 2011, 03:07:18 pm »
Probably, but only one way to find out. If you are going to play around in wet conditions use some moisture displacing lubricant or wire dryer to keep the moisture out.
