Author Topic: Seriously... where do I put the oil in?  (Read 8933 times)
Offline sbx22
  • 1974 1/2 ton 350 sbc
« on: September 27, 2011, 11:52:38 pm »
Final stages of putting back together my truck with a crate engine from tuff dawg out of Phoenix. So my question is, where do I put the oil in? See pictures attached. On top of both valve covers, are 2 breathers. I took off the passenger side breather, replaced it with PCV. I don't see where you would pour the oil in. Help?
Offline slammed79
  • Thou shalt not drive stock
Re: Seriously... where do I put the oil in?
« Reply #1 on: September 28, 2011, 12:56:26 am »
The emissions guys usually prefer the pcv valve on the drivers side. As far as adding oil, Pop one of those breathers off and go!
Praise the lowered
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: September 28, 2011, 04:15:50 pm »
That is where I got my 383, tuff dawg out of Phoenix--class act people there.
As far as putting oil in, if it's cloudy outside, you put oil in the left side valve cover.  If it is sunny, you put oil on the right valve cover.   ;D
Just pop off a breather or PCV valve.
What size engine did you get?
« Last Edit: September 28, 2011, 09:34:00 pm by SgtDel »
« Reply #3 on: September 28, 2011, 08:02:28 pm »
Remove oil drain plug, squirt oil in and put drain plug back in really fast.
Actually I think JCwhitney used to sell some piece of crap you drained and filled the oil out of the dipstick tube.  :D
But yes either side is fine to fill it.
« Reply #4 on: September 28, 2011, 09:28:26 pm »
also take the rubber grommet out of the breather hole. that will make the hole bigger
Offline sbx22
« Reply #5 on: September 28, 2011, 11:33:39 pm »
haha, ok, funny guys. I'm just so used to having an actual filler opening and cap. I just wanted to make VERY VERY sure before I did something and not ruin the motor. I got the 350, the one he sells for 1,995. Thanks!
« Reply #6 on: September 29, 2011, 01:03:18 am »
with these trucks you can poor oil in the carb and still be good lol
« Reply #7 on: September 29, 2011, 02:17:46 am »
make sure you use the proper oil. I would definitely get a oil primer and prime it before cranking it over. turn the engine over by the crank while doing it too.
Offline onelow84
« Reply #8 on: September 29, 2011, 05:22:31 am »
Vile that thing JC Whitney sells is handy when changing oil on an inboard motor on a boat...are they marketing it for cars and trucks?
Offline TexasRed
« Reply #9 on: September 29, 2011, 06:42:00 pm »
Vile, I think VW uses a lot of the extraction from the dipstick tube:
http://www.dieselgeek.com/product_p/pp-pela.htm
Offline Grim 82
« Reply #10 on: September 29, 2011, 07:22:27 pm »
^Definitely this if you have a flat tappet cam. I used Brad Penn break-in oil on mine, and only use that brand now. Their regular oil has the zinc your cam needs to live longer.
« Reply #11 on: September 30, 2011, 09:20:57 am »
     Now that there is dog gone funny, I don't care what side of the creek you woke up on.   :P  :o  ;D
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #12 on: September 30, 2011, 08:21:02 pm »
thanks, but i woke up IN the creek when i typed that.
