Author Topic: part help  (Read 5320 times)
Offline 87454westernhauler
part help
« on: October 03, 2011, 08:25:58 pm »
I have an 87 R10 chevy 305, 4speed with a posi in the rear that I bought off of my dad that I have bean trying to get runing and went to take it for a test drive and found out that a coon or something chewed a hole in the flex/ braded metal gas lines that run up the back of the motor next to the trans up to the throdle body. my local parts stores do not have them.I probably can get one from a junk yard, buti would prefer new ones.
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Online zieg85
Re: part help
« Reply #1 on: October 03, 2011, 08:45:19 pm »
You have 2 options that I know of... New ones from the dealer or have some made from a hose place.
Re: part help
« Reply #2 on: October 03, 2011, 09:16:37 pm »
I found a set by googling the OEM #'s but I also made a set. If you go to a decent autoparts store they should have fuel injection line repair hose and fittings.
Re: part help
« Reply #3 on: October 09, 2011, 07:45:23 pm »
I got a used set of them for 10 bucks, but now it is all jumpy and spazes when you accel.
Re: part help
« Reply #4 on: October 09, 2011, 11:43:16 pm »
     Are you sure you have them sealed and they are not sucking in air ?
Re: part help
« Reply #5 on: October 10, 2011, 06:05:06 pm »
i believe i do cause if i didn't it would be leaking gas every where because of the fuel pump being in the tank, I am wondering if the o2 sensor is bad?
Re: part help
« Reply #6 on: October 10, 2011, 11:59:34 pm »
check your codes. even with the cel off a code can still be stored
Re: part help
« Reply #7 on: October 19, 2011, 06:00:44 pm »
think that i figured out why it is surging, found out that the o2 sednsor is snaper off. just scored two runing and drivable trucks for 900 bucks, an 85 c20 custom with a new rebuilt 350 and an 89 gmc 1500 and just sold my rusted out old 80 c10 for 1500.  ;D
