Author Topic: Front brake rotor thickness K5  (Read 21374 times)
Offline Laderhosen
« on: October 08, 2011, 06:15:46 am »
Let my brake pads run a little too low, and they've scored the front rotors. Don't wanna have to replace the rotors/discs if I dont have to, so was thinking about getting them resurfaced.
Anybody know the minimum permitted thickness for the front rotors???
'82 3/4 ton, 350, th400,
'88 K5 Blazer, 350, 700R4
’98 BMW 328i daily drive
Re: Front brake rotor thickness K5
« Reply #1 on: October 08, 2011, 10:07:55 am »
     On the inside ( I believe ) on your rotor housing, there will be a stamped "min number" usually 0-0?? that is to be used to tell what the min can be on the rotor.  No matter where you take it to, they will look for that number and then measure it and tell you if they can turn it or not.
     If they are with in 0.01" or so and your scoring is deep they might not even try to turn them.
Offline Laderhosen
« Reply #2 on: October 08, 2011, 01:25:46 pm »
Ok thanks, I've just spent a load of money on cars this month and could really do without the expense!!
This is the scoring...
« Last Edit: October 08, 2011, 01:27:59 pm by Laderhosen »
« Reply #3 on: October 09, 2011, 04:06:40 pm »
     That looks pretty bad, the only way to know for sure is to look for the markings and use a mic and see, of course you are going to have to see how deep the scoring is.  Good luck.
« Reply #4 on: October 09, 2011, 05:20:58 pm »
i know when i was at pep boys with a friend we were hanging out in the garage where they wanted to turn down a rotor but they didnt know the specs and had to look it up. i dont know why they would have to look it up if it was stamped on the back
« Reply #5 on: October 09, 2011, 06:05:24 pm »
  Rotor Thickness                 {RPO JB1, JB3}  {RPO JB5, JB6, JB7, JD3, JD5, JD6, JD7} {RPO JB8, JF9}
  Nominal Thickness                    1.04 in               1.28 in                                                 1.53 in
  Minimum Refinish Thickness       0.98 in               1.23 in                                                 1.48 in
  Discard Thickness                     0.965 in             1.215 in                                               1.465 in
« Reply #6 on: October 09, 2011, 10:14:22 pm »
For all the work it takes to get the rotor off you would be money ahead just getting new ones. Plus its probably only $10 or $15 more each to get new vs turning them.
« Reply #7 on: October 09, 2011, 11:37:12 pm »
     I just got new rotors for my k10, $85.00 a piece for the hub and rotor combo's.  In my opinion if your old ones are questionable at all, well worth the price for new ones.
« Reply #8 on: October 10, 2011, 12:06:02 am »
i thought i was told to turn them down its either 10 or 20$ vs a new rotor/hub is 80+
Offline slammed79
  • Thou shalt not drive stock
« Reply #9 on: October 10, 2011, 08:38:48 am »
I used to work for Checker auto parts when I first moved to Arizona, and to be honest with you, I probably wouldn't even try to turn that rotor, its pretty hammered and would eat up a fresh set of cutters quick. Best to just replace. Just my .02
Praise the lowered
« Reply #10 on: October 10, 2011, 09:33:08 am »
     Your right Irish, around sac ( which should be higher than most places ) it is inbetween $15.00 - $25.00 to turn them.
« Reply #11 on: October 10, 2011, 01:30:04 pm »
Rotors around my area are $25 - $35 to turn, and new rotors are about $50 - $60ish.
Offline Laderhosen
« Reply #12 on: October 10, 2011, 02:02:19 pm »
They ain't that cheap here! Cheapest I can find is £170 for these trucks, which at the current exchange rate is about $250. Absolutely crazy price.
Offline Laderhosen
« Reply #13 on: October 10, 2011, 02:15:31 pm »
... I may just get some new ones on mail order from the States. I'm replacing the front locking hubs with manual ones anyway so might just renew all of it, throw some new bearings on there too.
Having just had to spend $1600 getting my girlfriend's car's head rebuilt with new cams etc it's just a drop in the ocean!!!
« Reply #14 on: October 10, 2011, 06:38:16 pm »
I'll tell ya, I love having an on car lathe especially with 4WD's - Adjust wheel bearings if necessary and perfect refinish without removal and zero runout. You may want to check with your local shops and see who has an on car lathe. It may be cheaper for you to just pay to have them resurfaced on the truck.
