Author Topic: Windshield install  (Read 18119 times)
Offline Engineer
Windshield install
« on: October 10, 2011, 07:51:25 am »
Is there any trick to installing the windshield in our trucks?
I got the windshield out without busting it, but don't want to break it putting it back in.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline 1979C20
  • Kyle Taulton.
Re: Windshield install
« Reply #1 on: October 10, 2011, 08:05:38 am »
http://www.youtube.com/watch?v=R1ilXMfyo7c&feature=youtube_gdata_player
Same process for the windshield and rear window. I dont know if you NEED the special tools or not.
« Reply #2 on: October 10, 2011, 09:35:45 am »
     I used to years ago build bed toppers, they are a little different, but 1979c20 has the right idea.  Same principle and you can find all kinds of vid's on u-tube.  It really is not that hard if you take your time.
Offline RCCoors
« Reply #3 on: October 10, 2011, 10:31:48 am »
http://www.youtube.com/watch?v=eaSVkbogXNk
This video shows exactly how its done on our trucks for both the front and back glass.
Hope it helps ya out!
77' C20  350/TH350  4.11  14Bolt FF
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: October 10, 2011, 10:53:41 am »
Im not sure if different models use different windshield mounts, but my silverado uses the locking strip on the front and rear. That 67 is way different than mine.
« Reply #5 on: October 10, 2011, 01:36:32 pm »
Clean the rubber, put it on the cab, set the bottom of the glass into it, lay it back onto the rubber, then use a non metalic spoon type of thing to work the glass down into the gasket. A 5 gallon paint stir stick sanded down works good for this. They make a tool for this as well, its made out of plastic, I forget what its called. Glass guys call them "bones". You will also want to lube the rubber up with spray foam window cleaner. You can install the lock strip with a screw driver etc. but they make tools just for it. They are not to expensive.
Offline Engineer
« Reply #6 on: October 10, 2011, 08:30:43 pm »
Thanks for the quick replies guys.
I'll give it a shot here one of these days.
I've done several rear windows, but never a windshield.
When I did the back windows I used the method Blazin described, however, I may try putting the rubber gasket on the windshield, and then set it in the truck.
Offline 1979C20
  • Kyle Taulton.
« Reply #7 on: October 10, 2011, 09:12:02 pm »
I wouldnt do that, youll be fighting it for hours.
« Reply #8 on: October 10, 2011, 11:27:32 pm »
Rear window you use a rope in the rubber, Winshield you put the gasket on the truck, and then the glass in.
Offline Engineer
« Reply #9 on: October 17, 2011, 05:27:51 pm »
I just put my windshield in. Thanks much for the advice guys.
I wasn't having much luck getting the window gasket to stay on the cab, so I put it on the windshield, then dropped it into the cab. One thing I did different......instead of using a rope, or string, I used some of that plastic weed eater string. I am glad to report it worked like a champ!
That YouTube video said to use foaming window cleaner on the rubber gasket. But by using the weed eater string I was able to roll the gasket in dry with out any issues.
Whole job took about 10mins start to finish. :)
Offline low budget
« Reply #10 on: October 18, 2011, 09:33:26 pm »
A friend of mine used to own a glass shop.  I helped him set a lot of windshields and we used the rope trick.  Slick as a whistle...
