Body, Glass & Paint
Windshield install
Topic: Windshield install (Read 18116 times)
Engineer
Windshield install
October 10, 2011, 07:51:25 am »
Is there any trick to installing the windshield in our trucks?
I got the windshield out without busting it, but don't want to break it putting it back in.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
1979C20
Kyle Taulton.
Re: Windshield install
October 10, 2011, 08:05:38 am »
http://www.youtube.com/watch?v=R1ilXMfyo7c&feature=youtube_gdata_player
Same process for the windshield and rear window. I dont know if you NEED the special tools or not.
bake74
October 10, 2011, 09:35:45 am »
I used to years ago build bed toppers, they are a little different, but 1979c20 has the right idea. Same principle and you can find all kinds of vid's on u-tube. It really is not that hard if you take your time.
74 k10, 77k10 Tom
RCCoors
October 10, 2011, 10:31:48 am »
http://www.youtube.com/watch?v=eaSVkbogXNk
This video shows exactly how its done on our trucks for both the front and back glass.
Hope it helps ya out!
77' C20 350/TH350 4.11 14Bolt FF
1979C20
Kyle Taulton.
October 10, 2011, 10:53:41 am »
Im not sure if different models use different windshield mounts, but my silverado uses the locking strip on the front and rear. That 67 is way different than mine.
Blazin
Blazin new trails!
October 10, 2011, 01:36:32 pm »
Clean the rubber, put it on the cab, set the bottom of the glass into it, lay it back onto the rubber, then use a non metalic spoon type of thing to work the glass down into the gasket. A 5 gallon paint stir stick sanded down works good for this. They make a tool for this as well, its made out of plastic, I forget what its called. Glass guys call them "bones". You will also want to lube the rubber up with spray foam window cleaner. You can install the lock strip with a screw driver etc. but they make tools just for it. They are not to expensive.
Engineer
October 10, 2011, 08:30:43 pm »
Thanks for the quick replies guys.
I'll give it a shot here one of these days.
I've done several rear windows, but never a windshield.
When I did the back windows I used the method Blazin described, however, I may try putting the rubber gasket on the windshield, and then set it in the truck.
1979C20
Kyle Taulton.
October 10, 2011, 09:12:02 pm »
I wouldnt do that, youll be fighting it for hours.
Blazin
Blazin new trails!
October 10, 2011, 11:27:32 pm »
Rear window you use a rope in the rubber, Winshield you put the gasket on the truck, and then the glass in.
Engineer
October 17, 2011, 05:27:51 pm »
I just put my windshield in. Thanks much for the advice guys.
I wasn't having much luck getting the window gasket to stay on the cab, so I put it on the windshield, then dropped it into the cab. One thing I did different......instead of using a rope, or string, I used some of that plastic weed eater string. I am glad to report it worked like a champ!
That YouTube video said to use foaming window cleaner on the rubber gasket. But by using the weed eater string I was able to roll the gasket in dry with out any issues.
Whole job took about 10mins start to finish.
low budget
October 18, 2011, 09:33:26 pm »
A friend of mine used to own a glass shop. I helped him set a lot of windshields and we used the rope trick. Slick as a whistle...
Body, Glass & Paint
Windshield install
