Author Topic: Problem finding a u joint that fits  (Read 13907 times)
Offline 84chevysilverado
« on: October 15, 2011, 05:14:35 pm »
I Am in the process of replacing my rear drive shaft u joints and I ran into an issue. The parts guys say that both u joints on the rear shaft are identicle so I got both u joints. When i tried to put the u joint in in the front position where the slip yoke is I noticed that the cup size on the shaft match my new u joint but the cup sizes on the slip yoke are way bigger. If you look at the u joint 2 cups are small and 2 cups are quite a bit bigger. The local napa dealer cant seem to find anything like this u joint. Its an 81 jimmy with a np208 transfer case as far as I know its all from factory. Anyone had this prob or no where I can find this u joint? On the u joint is stamped spicer to with a set of numbers we tried to cross match them at the store but had no results
Offline 1979C20
  • Kyle Taulton.
Re: Problem finding a u joint that fits
« Reply #1 on: October 15, 2011, 05:34:05 pm »
The drive shaft is probably from a different vehicle. What you need is a conversion ujoint. Fo you have the old one(s) still? Take those to the store with you if you do
« Reply #2 on: October 15, 2011, 05:45:03 pm »
     x2, take the old ones and match them up, don't worry about finding year and make, match what you have in your hand, then find out what it is off of.
« Reply #3 on: October 15, 2011, 10:27:30 pm »
I already did no luck. but I just now I typed in conversion u joints in google and I found a company that sells all kinds. Thanks for the help guys
« Reply #4 on: October 16, 2011, 01:52:53 am »
dont waist your money with a company thats makes conversion u joints. i know when i was at autozone we would get people whos u joint didnt match the computers so i would open every box till i found one or knew we didnt have it. napa is good if you know whats year parts you have.
« Reply #6 on: October 16, 2011, 03:39:23 pm »
