Author Topic: 700r4 3spd w/o overdirve or a 3spd w/overdrive, do you know?  (Read 2987 times)
Offline kdime
« on: October 16, 2011, 02:21:56 pm »
first off if anyone thinks that a 700r4 is a 3spd with no overdrive please say so.
well ur wrong its a 3spd WITH OVERDRIVE. the guys on dieselbombers forum are trying to argue that there are some regular 3spd 700r4's. i just want to make sure im not going insane here...
life sucks sometimes... you just have to take it in stride
Re: 700r4 3spd w/o overdirve or a 3spd w/overdrive, do you know?
« Reply #1 on: October 16, 2011, 07:05:13 pm »
     As far as I know the 700r4 is a 3 speed with overdrive.  The 200r4 is a 3 speed.
Offline Da67goatman
  • Burban
« Reply #2 on: October 16, 2011, 08:42:48 pm »
The THM700r4 has 4 gears 3.06, 1.63, 1.00, 0.70 overdrive, the THM200 was a 3 speed auto but very weak, The THM200-4r was a redesigned THM200 with an additional overdrive gear making it a 4 speed auto that in stock form is stronger then a 700r4 and has the benefit of a multi pattern bellhousing, ratios are 2.74, 1.57, 1.00, .67.
<Pitcrew>
