Author Topic: I don't know if this is good or bad (volt meter)  (Read 5313 times)
Offline audrima
« on: October 17, 2011, 02:36:39 pm »
the reason I ask is that a year old battery just totally died on me. It would not take a charge or anything. I don;t want that to happen to the replacement. the Alt is new (since Feb) and is form advance auto. that is a picture of the Volt gauge at idle. is it over charging?
thanks
<3
Mariah (keep my truck dang it!)
Re: I don't know if this is good or bad (volt meter)
« Reply #1 on: October 17, 2011, 04:59:09 pm »
According to the gauge you should be fine.
« Reply #2 on: October 17, 2011, 05:32:06 pm »
I dont fully truck any gauges especially on electrical component. Check with a multimeter at the battery when the truck is running. In my experience anything over 14 volts will bake a 12 volt battery. i like to see 13.8 volts max on a 12 volt system when the engine is running. the gauge does say ok, but Id double check to make sure.
« Reply #3 on: October 17, 2011, 06:43:33 pm »
Agreed, check with a meter.
