Author Topic: my brake lights stopped working! need help!  (Read 6888 times)
Offline ammmotroop
« on: December 22, 2003, 07:08:00 pm »
My brake lights recently stopped working. The tailights still work as do the reverse lights. I tried changing the bulbs but that did not help. Any ideas?
Offline smokin77
Re: my brake lights stopped working! need help!
« Reply #1 on: December 22, 2003, 06:49:00 pm »
The brake light switch on the brake pedal. Mine went twice, once the part of it for my tranny lockup went, then in the new one the brake lights went. Put a new switch in its been great for about 5 months now!
Offline ammmotroop
re: my brake lights stopped working!
« Reply #2 on: December 22, 2003, 07:29:00 pm »
thanx for the tip. Where on the brake pedal is the switch located and how an i tell if it is shot?
Offline smokin77
Re: re: my brake lights stopped working!
« Reply #3 on: December 23, 2003, 03:47:00 pm »
Its above the brake lever, underneath the dash. First, push the brake pedal down and watch the switch to see if the button comes out, it could just be gettin stuck. If it looks fine, take out the switch or just unplug it and if you have an ohmmeter check the switch out. It should read low ohms with the button out, and high ohms with it pushed in. If it reads high both ways the switch is bad.
If you dont have an ohmmeter you may wanna pickup a new switch, you could always return it. I payed $5.87 for mine.
Brake lights
« Reply #4 on: December 25, 2003, 10:13:00 pm »
You can jump the two wires across and if the lights come on the switch is probably junk.
