Author Topic: 2WD Tire Size  (Read 14831 times)
Offline 123 pugsy
2WD Tire Size
« on: January 25, 2006, 07:30:00 am »
I'm thinking of using Firestone Destination AT tires on my 1976 LWB 2WD and am looking for opinions on sizes.I'm thinking of using 30x9.5 or 31x10.5.Does anyone have something like these sizes on their 2WD and if so which one...how does it look...
Pugsy
76 C10 LWB
TPI 350
Offline ChevyGuy
tires
« Reply #1 on: January 26, 2006, 04:20:00 pm »
I have 31X10.50's all the way around and it looks good, makes your truck alittle taller but it takes away from the handling alittle. I like 255/70's all the way around. It fills the fender well without a large tire. Or you can run smaller tires in the front and bigger in the rear like 235/70's in the front and 255/70's in the rear. Im talking all about 15 inch tires it depends on what you want. Just a suggestion.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
tires
« Reply #2 on: January 26, 2006, 10:40:00 pm »
From the law-enforcement mentality I have, don't forget to re-calibrate your speedo b4 it's too late.  You'll be going much faster w/ larger tires than what it reads.
SgtDel
Offline 123 pugsy
Re: Tire size
« Reply #3 on: January 27, 2006, 01:34:00 pm »
Thanks Chevyguy.I had those sizes on my last truck(79 SWB 2WD with 455 Rocket and Cragers) except 60's on the back and it looked quite nice.This time I'm going for more of a truck as in non high performance(283 with 700r4) and I want tires that can pull my boat up a gravel boat launch.
Sgt. Del,thanks for that.I haven't installed the engine or tranny yet so I still have the pleasure of sizing up the speedo gears ahead of me. My rear axle is 3.40 gear and what I would like to achieve is a decent looking truck with good milage,reliabilty and traction in snow,gravel...
Pugsy
76 C10 LWB
TPI 350
Offline Ziptar
Re: Tire size
« Reply #4 on: February 05, 2006, 09:02:00 am »
Last year when I got my tranny at the wrecking yard, a truck had just come in with 15 x 8 Rallys and Michelin 30 x 9.5 x 15 XC LT4's that were brand spanking new. Wrecking yard guy said $40 for the pair, so I grabbed them.
I just put them on the rear of my 85 last weekend, the rims had been painted black and looked like crap so I re-did them and the fronts to match with a $0.96 rattle can of Walmart Flat Black, it'll do for now. The front tires are 235/75-15s on 15x8 rallys.
Took a pic, don't know if that helps you any.
Edited by: Ziptar at: 2/5/06 9:03 am
Offline 87swb
tire size
« Reply #5 on: February 06, 2006, 04:26:00 pm »
i have an 87 2wd swb. it has 255-70-r15s all the way around and it looks good. gives the truck a muscular look i think. bad thing about small tires in the front and bigger ones in the back is that you can't rotate, well you can rotate them but it will look GOOFY as heck and probably handle funny. and i always heard you had to have more front end alignments done with this set-up.
Offline 123 pugsy
Re: Tire Size
« Reply #6 on: February 09, 2006, 05:50:00 am »
Thanks for the photo Ziptar.The 30" tires look good.I think I will go with the 31" as they are 1" wider;should look a little bit beefier.
Pugsy
76 C10 LWB
TPI 350
Offline DnStClr
Re: Tire Size
« Reply #7 on: February 10, 2006, 07:31:00 pm »
I like my Cooper Discoverer ATs. I would get 31-10.50-15's
image24.webshots.com/24/6...chF_ph.jpg
Edited by: DnStClr at: 2/10/06 7:40 pm
Don
87 Chevy Silverado
Offline 123 pugsy
Re: Tire Size
« Reply #8 on: February 10, 2006, 08:03:00 pm »
I ordered the Firestone Destination A/T's today.Size:31x10.5x15".Should be good tires.Good reviews on The Tire Rack. Thanks guys.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
Re: Tire Size
« Reply #9 on: February 14, 2006, 04:49:00 pm »
And again
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
Re: Tire Size
« Reply #10 on: February 14, 2006, 04:54:00 pm »
Finally,I think I got it.31x10.5's will look quite nice.
Pugsy
76 C10 LWB
TPI 350
Offline roundedline
Re: Tire Size
« Reply #11 on: February 14, 2006, 05:35:00 pm »
