Author Topic: Brakes Locking  (Read 6265 times)
Offline discot315
  • Trevor - 1980 Chevy K10
Brakes Locking
« on: November 02, 2011, 01:13:07 am »
Driving to work this morning I was going down a hill and put the clutch in and just tapped the brakes and it locked up and I stopped completely, I tried it again after and it did it again.. Any ideas what that could be?
1980 K10- 9" lift with 38's. 350 4speed lwb
1976 / 85 front clip K20 - 4" lift with 33's. 350 4speed lwb
Offline 1980c10
Re: Brakes Locking
« Reply #1 on: November 02, 2011, 01:52:29 am »
Was it the front or rear or all of  the brakes locking up?
Re: Brakes Locking
« Reply #2 on: November 02, 2011, 07:29:16 am »
     This answer would help in determining/isolating where the problem could be coming from.  Have you had any work done to your master cylinder lately ?  ( also, did both back lock up or just 1, or same with front, could be a wheel cylinder )
Re: Brakes Locking
« Reply #3 on: November 03, 2011, 08:58:09 pm »
Drum brakes when out of adjustment can cause this too.
Offline discot315
Re: Brakes Locking
« Reply #4 on: November 04, 2011, 12:53:26 am »
Well before I bought the truck the guy did all the brakes when he lifted it. new master cylinder, all new hard and soft lines and apperently the pads and such. I tried again yesterday and it didn't do it but today I noticed it once. I'm not really sure if its front /back or what wheel. How could I check? and what could cause this?
Offline 1980c10
Re: Brakes Locking
« Reply #5 on: November 04, 2011, 07:36:29 pm »
The adjusters can also get sticky. Whenever I do a rear brake job on one of my vehicles i will clean up the threads and apply some anti sieze. When I remove a caliper I clean up the slides and grease them as well.
Raise the vehicle and see if any of your wheels are dragging, then a careful inspection can give you some clues; look for uneven wear or broken parts etc and post back the results
Offline drtch1
Re: Brakes Locking
« Reply #6 on: November 04, 2011, 09:11:31 pm »
My back brakes did this. I bought the wrong rear wheel cylinders. They have 4 different sizes for my year (86). When I put on the brakes the rears would lock up. All depends on your rear brake drum size.
« Last Edit: November 04, 2011, 09:19:34 pm by drtch1 »
