Author Topic: won't turn over??!  (Read 34265 times)
Offline 2502
Re: won't turn over??!
« Reply #15 on: November 06, 2011, 04:57:18 pm »
i gave up tonight cuz it got dark early and cold quick. i'm frustrated and ready to set it on fire.
« Reply #16 on: November 06, 2011, 05:13:26 pm »
so where did the fuel stop flowing to?
Offline 2502
« Reply #17 on: November 06, 2011, 09:51:34 pm »
you got me. the truck just died at the gas station one night, wouldn't start back up.
it seemed to be a fuel issue, so i checked the fuel pump and couldn't hear it click on so i replaced the pump. now it's working fine, gas is getting all the way up front but it's not starting still. so we pulled it apart and cleaned the injectors, and now it's dumping fuel. when i turn the ignition. it didn't seem like the gasket sealed right so we redid the gasket so i'll try it again tmorrow when there's light
Offline 2502
« Reply #18 on: November 07, 2011, 12:42:09 pm »
checked the fuel injectors, not sure how to test if they're not working or what...
the gas was coming TO the injectors but still doesn't seem to wanna start up.
any suggestions?
« Reply #19 on: November 07, 2011, 12:54:41 pm »
Is it still leaking?
Offline 2502
« Reply #20 on: November 07, 2011, 01:04:45 pm »
no when bill put the injectors back in he missed the o rings. i just bought the gasket kit and we replaced those so no leak. it starts up, and dies.
it was leaking around the injectors, so the fuel is at least getting there, just past that i can't figure out what to check test or replace. and i'm trying to have a better guess since i'm on a limited budget now to fix it
« Last Edit: November 07, 2011, 01:06:23 pm by 2502 »
« Reply #21 on: November 07, 2011, 03:08:13 pm »
will it run on carb clean?
« Reply #22 on: November 07, 2011, 03:29:26 pm »
I am betting on the regulator/Diaphram and the lack of fuel pressure...
Offline 2502
« Reply #23 on: November 07, 2011, 06:27:11 pm »
if it sits for a few minutes, it starts up normal, then dies out right away. i'm thinking pressure. but i'm an idiot and know nothing i'm just thinking if this were the problem on my bike, it would most likely be this:\
friend of mine thinks it's the injectors, which are like $80 a piece, i had a ton of stuff for my 79 that was still brand new so i returned it to get credit to get the injectors, and one location had one, another location had another. so i grabbed one, we drove to the other one, and it's the wrong injector in the right box. so now i have to wait for one to come in.
i still think it's pressure related. i never checked the fuel pressure cuz i didn't have the gauge to do so. i mean it's getting gas up to the tbi, and it seems to stop at the injectors. when we overlooked the missing o rings at the top it was spilling down in there so it's getting fuel it's just not doing anything past that point.
« Last Edit: November 07, 2011, 06:30:12 pm by 2502 »
« Reply #24 on: November 07, 2011, 06:29:50 pm »
Pinch the rubber return hose off and see what happens
Offline 2502
« Reply #25 on: November 07, 2011, 06:30:42 pm »
and see if it doens't start or what would i be looking for?
« Reply #26 on: November 07, 2011, 09:03:49 pm »
Pinching the return hose will increase the fuel pressure on the supply side so if you have a bad regulator bleeding off the pressure this should negate it...  Or if you have a leak, this will expose it.
Offline 2502
« Reply #27 on: November 07, 2011, 10:30:31 pm »
ok thanks i'll try that tomorrow when we got some light. i just want the thing to run i'm falling behind on t shirts i have to print with no truck to get back and forth to the shop
Offline 2502
« Reply #28 on: November 08, 2011, 04:53:21 pm »
during troubleshooting today, hooked up a 9volt batt to the injectors.
they sprayed just fine, truck started up. so my injectors aren't getting power from.... __________?
« Reply #29 on: November 08, 2011, 05:12:22 pm »
The ECM triggers the Injectors to fire.  Do you have anything disconnected?  Any broken/frayed wires?.  The injectors are tied into the fuel pump and oil pressure switch, are you gettting oil pressure?  Is it connected?  The only other thing I could thing of it the ignition module.
