Author Topic: Your thoughts on this idea  (Read 40974 times)
Offline Skunksmash
« on: November 06, 2011, 06:51:40 pm »
This thread is for those of you who are familiar with the gauge cluster innards. 87 model. I'm not happy with the way I currently have my gauges set up. I don't have them mounted like I want them. Well, I think I can get them all recessed behind the factory bezel, using the factory printed circuit if I do this right. The printed circuit will bend, unlike other setups where they use one of those green PCB boards. That is the only reason this method will work. I think...
Anyway, I plan to take the appropriate grit of sand paper, and sand off a couple of very small spots on the printed circuit, to expose the copper filament underneath. Just enough to make a place to solder. Then solder the wire that I'm needing to run, to that copper thing. Then throw down some clear silicon or something on the solder point to sort of strengthen the solder point. If the sanding part is even necessary. It might not be necessary if I can just solder to the already exposed copper points on the printed circuit, that were originally open so that they could contact the lights and various power points and signal emitters and stuff.
To make a hole in the factory gauge housing, I'm going to just cut a hole in it large enough to fit the new 5" tach. I've checked and there appears to be room. I will lose the "fasten seat belt" and "Parking Brake" lights that come factory in the dash, but I don't really care. So since the printed circuit can bend, I can just bend it and fasten it over somehow. That way my big tach can fit where it needs to go, and so I don't have to ditch the stock setup for the rest of the gauges. Can't really afford to buy all new gauges right now but I did get a few of the necessary ones. Necessary at least, in my opinion. So what do you think? Can you forsee any problems with this idea?
« Last Edit: November 07, 2011, 09:44:51 pm by Skunksmash »
Offline Da67goatman
  • Burban
Re: Your thoughts on this idea
« Reply #1 on: November 06, 2011, 09:06:24 pm »
Not having a fuel gauge...
<Pitcrew>
Offline 1MCP7.3/87GMC
  • 75s my baby
« Reply #2 on: November 06, 2011, 09:39:09 pm »
Why not just get a factory gauge cluster with a tach and not have to cut the circits at all?
1984 Chevy Silverado 2wd swb (311hp 350) El Diablo Rojo
1975 Chevy Scottsdale 4wd swb  silver slug 350 tbi
1987 GMC Sierra 4wd lwb 350 stock replacement
Offline Skunksmash
« Reply #3 on: November 07, 2011, 03:02:22 am »
Factory tach looks kinda...abnormal with zeros after the numbers. Looks like some kind of other speedometer or something. But I wasn't going to cut the circuit, I was going to fold it over a little and leave it that way. Also, the fuel gauge will be replaced with a smaller one that I have, which will be fitted into the clock's old spot.
Offline jaredts
« Reply #4 on: November 07, 2011, 07:36:04 am »
Maybe I'm misunderstanding, but a new aftermarket tach will require a bat. pos., lighted pos. from dimmer (for backlight), ground, and tach signal wire.  None of those would I get from the printed circuit, so I don't see the need to sand and solder to the pcb.  You just have to run a few wires and figure out how to physically fit it in there.
« Reply #5 on: November 07, 2011, 12:21:15 pm »
Ditto on what jaredts posted.  Of course I am still confused as to what you want to do...
Offline Skunksmash
« Reply #6 on: November 07, 2011, 09:51:41 pm »
Sorry I should have been more clear on that. Yeah the tach will have to have its own wiring of course, but the new autometer fuel gauge and the digital water temp gauge might be able to benefit from just having their wiring (some of their wiring at least) soldered to the correct spots on the factory PCB. That way, I don't have to deal with the dimmer aspect of things, which I was never able to get working on any more my gauges. Didn't try real hard though. Also, if I am stuffing this tach in there, the PCB does have to be folded over simply because there is no longer room for it with that big tach in there. So that presents a couple of minor issues. I'll post up a couple of pics tomorrow.
Offline Skunksmash
« Reply #7 on: November 09, 2011, 08:21:30 pm »
Ok here are some pics that might help explain what I want to do. I'd like yall to look at them and tell me what you think. Good, bad, or ugly. And maybe some recommendations.
« Last Edit: November 09, 2011, 08:23:18 pm by Skunksmash »
« Reply #8 on: November 09, 2011, 09:07:56 pm »
Are you planning on keeping all the other stock gauges?  I started down this path and you will end up hacking that cluster housing to death.
Honestly you would be better off going this route:
http://73-87.com/7387garage/interior/gauges_recessed.htm
Offline Skunksmash
« Reply #9 on: November 10, 2011, 02:00:14 pm »
Yeah I'd like to do that, but only working part time due to school I simply can't afford to buy everything necessary. I can only do a little here, a little there. And for now, yes I do plan on keeping the other stock gauges.
Offline jaredts
« Reply #10 on: November 10, 2011, 02:07:28 pm »
Why would you have to fold the printed circuit over?  Couldn't the tach just bulge out the back and push it back a little?
Offline Skunksmash
« Reply #11 on: November 10, 2011, 03:10:28 pm »
I guess you could, but it does still need to be secured some kinda way. Cause I don't want it just being loose back there.
« Reply #12 on: November 10, 2011, 03:12:19 pm »
If you are worried about the printed circuit, just tape it down, just don't crease it.
Offline Skunksmash
« Reply #13 on: February 29, 2012, 07:33:01 pm »
Ok now I have to drag this topic back up. Is there some kind of tach lead wire on the coil of an 87? I am about to wire up my tach properly, and it looks like there is some little wire coming off the coil. Just a little 4 inch wire with a little plug on the end of it, coming right out of one side of the plug that plugs into the coil. I thought this could be awful convenient for me, if its just a negative test lead that goes straight to the coil. I could just wire my tach signal wire, right to the little plug looking thing on the end of the wire. Its not plugged into anything, so I have no idea what its for.
« Reply #14 on: March 01, 2012, 10:28:24 am »
The HEI has a plug for TACH, just use that.
