Author Topic: Your thoughts on this idea  (Read 40975 times)
Offline jaredts
Re: Your thoughts on this idea
« Reply #45 on: April 11, 2012, 07:51:42 pm »
I don't know what the added fuse and circuit was for or what you need another circuit for now--I guess I could go back through the pages of the post.  If the fuse that you already added would be appropriate to also protect whatever you're doing now then I just meant to solder or use a butt connector of some type to tap into the wire coming out of that fuse.  You could also buy an inline fuse and appropriate connector to plug into an ign slot in the fuse box.
Offline Skunksmash
« Reply #46 on: April 12, 2012, 02:56:42 am »
Yeah i got some spade connectors to try to use the extra aux ING slot. Odd that they made it to where a simple fuse wouldn't fit. I'm using the other ING slot for my new water temp gauge, and something else that was in there already, that I didn't bother to look up yet.
Offline Skunksmash
« Reply #47 on: April 15, 2012, 07:16:28 am »
They fit, got it all rigged up. Job done. So nice that they put some aux "key on" slots in there.
« Reply #48 on: April 18, 2012, 08:27:17 pm »
I don't follow?and don't you mean IGN?
Offline Skunksmash
« Reply #49 on: April 19, 2012, 01:09:27 pm »
A regular fuse won't fit in the aux IGN slots that they made available. And yeah i mean IGN i was used to this little honda i used to have where it was aux .
Offline Skunksmash
« Reply #50 on: April 25, 2012, 12:01:13 am »
Ok I got a problem. Do you guys know what signals to look for, on the Voltage gauge, and the Oil pressure gauge? I take it the oil pressure gauge is looking for a certain amount of OHMs of resistance, right?
And what is the voltage gauge looking for? Whats the signal?
