Author Topic: squeeling noise??  (Read 7453 times)
Offline 81chevyskullc10
  • 81chevyskullc10
squeeling noise??
« on: November 07, 2011, 02:24:56 pm »
I bought this truck 2 months ago and I also posted a issue about my power steerig bracket and how it squeels when romp on it. My altenator went out so I replaced it. Now the squeeling is there not stop and it sounds like it is coming from my water pump. I do not like the V belts but i do not have the time to go to the junk yard and obtain a single belt system or the money. I noticed the waterpump pully  is wobbleing as it is turning. Any suggestions on this ( I imagine I need to replace Water pump because when i start truck up it continous to keep squeeling until i put it in drive, then when i stop and shut motor off it will making a squek noise also, any help will be great
Brian
Re: squeeling noise??
« Reply #1 on: November 07, 2011, 03:37:50 pm »
Take the belt off the alternator and see if the constant squealing stops.
  • 81chevyskullc10
« Reply #2 on: November 08, 2011, 09:19:13 am »
it only seems to do it when there is pressure put on it by the belt. It is not the alternator but the water pump is only 30 bucks so ill try replacing it. :-\
Brian
« Reply #3 on: November 08, 2011, 12:24:37 pm »
     If your water pump pulley is wobbling when the engine is running, replace it and report back.  Also v-belts when they start to wear and dry out, they will squeal or make noise.  Might also try replacing belts.
  • 81chevyskullc10
« Reply #4 on: November 08, 2011, 01:42:08 pm »
replace the pump?
Brian
« Reply #5 on: November 08, 2011, 04:37:38 pm »
replace the pump?
     You stated your water pump pulley is wobbling, I made an observation that it should not wobble, therefor fix it by replacement of either the bent pulley or the shaft on the water pump is bent, therefor replacement is in order.
Offline thirsty
    • Suitor's Garage
« Reply #6 on: November 08, 2011, 06:22:42 pm »
If your water pump is bad it may also be leaking some antifreeze on the pulley making it squeal.
  • 81chevyskullc10
« Reply #7 on: November 08, 2011, 06:44:53 pm »
k I will replace it then, its only 30 bucks but I thought I would ask to see what some other peeps thought...Thanks everyone!
Brian
  • 81chevyskullc10
« Reply #8 on: November 09, 2011, 05:01:49 pm »
getting water pump on saturday, i will let everyone know how it goes
Brian
Offline Grim 82
« Reply #9 on: November 11, 2011, 01:21:22 pm »
I would replace the clutch fan too while you are at it. Also make sure your belts are in the proper grooves if you have multiple groove pulleys.
Offline Sodium Duck
« Reply #10 on: November 11, 2011, 05:06:41 pm »
Anyone got a part # for the fan clutch? Doing my water pump as well this weekend and would like to do it all at once.
1985 K10, corporate 10-Bolts front and rear, 6" lift, 35's, 305, auto, longbed.
