Author Topic: ECM information for 1985 C10  (Read 19497 times)
Offline sleepchamber
  • working on it...slowly...
« on: November 14, 2011, 10:02:37 am »
Ive dug around in here and cannot seem to find specifics on what the ECM controls/monitors in a 1985 C10.  The previous owner has replaced the carb with an Edelbrock...not sure if the distributor has been swapped but it does have two extra connections that my past non-ECM chevys didnt have.  Im just wanting to get all of the uneeded wiring out of the bay.
1985 Scottsdale C-10
Re: ECM information for 1985 C10
« Reply #1 on: November 14, 2011, 05:47:50 pm »
I thought that a couple of wires from the ECM plug in had to be connected to bypass it all or just get a new HEI distributor like most have done.
« Reply #2 on: November 14, 2011, 06:37:27 pm »
How can I tell if the distributor is stock or non computer controlled? I suppose there would be a circuitboard of some type inside right?
« Reply #3 on: November 14, 2011, 06:42:05 pm »
« Reply #4 on: November 15, 2011, 10:16:46 am »
There is a post here about this and a link on 73-87.com on how to convert a ESC distributor.
« Reply #5 on: November 15, 2011, 01:39:44 pm »
So after looking around the site, I have confirmed that my ESC distributor has been removed already and replaced with a standard HEI.  As long as my distributor and carb are non-ECM then I should be able to totally remove the ECM and all related wiring?
« Reply #6 on: November 15, 2011, 07:19:13 pm »
Yes, you can ditch it.
« Reply #7 on: November 15, 2011, 08:44:49 pm »
Quote
So you weren't referring to the distributor having extra connections then what were you talking about? Where are the extra connectors?
« Reply #8 on: November 15, 2011, 09:02:16 pm »
There are two smaller clip on connections in front of the ignition connection...where a tachometer would normally connect to the distributor ......I have no tachometer.
