Author Topic: which factory front springs provide lift  (Read 10385 times)
Offline redneckfarmer
« on: November 17, 2011, 07:19:45 pm »
would any one on hear happen to know which years or models( 1/2 3/4 of 1 ton) 4x4 trucks did not have the inverted front springs from the factory ? i was trying to locate a set to lift the front of my 1/2 ton 1980 4x4 and did not know what model of truck to lok for them on
Offline Jason S
Re: which factory front springs provide lift
« Reply #1 on: November 17, 2011, 10:13:04 pm »
How much of a lift are you wanting and how much ride difference would you allow?
« Reply #2 on: November 20, 2011, 06:22:10 pm »
i was wanting 2 or 3 inches of lift and ride dont matter at all to me
Offline Senck243
« Reply #3 on: November 20, 2011, 10:22:19 pm »
Why not just to 2.5 add a leafs? I think rough country makes them
1984 k10 305, sm465, np208
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: November 21, 2011, 02:16:52 am »
Considering yours is a half ton, 1 ton spings might lift it a bit. I dont know if it would be frowned upon, but maybe you can flip your front springs over and bolt them on so you have a positive ar,h? I dont know if there is any safety issues with that.
Offline rustymitchell
« Reply #5 on: November 21, 2011, 09:24:17 am »
Look for a stock 3/4ton with heavy duty brakes (look for the 13inch drums on the rear end).  It will have heavier spring packs front and back.  In the front it is basically just an add-a-leaf though.  I think they would be worth about an inch or two of lift.  You could also get your springs re-arched and use the add-a-leaf kit as mentioned above.
79K20  350 sm465 np205
76C10  350 TH350
« Reply #6 on: November 21, 2011, 11:27:31 am »
The amount of work put into front spring change isn't worth it if you just going to put negative arch springs back in it, only going to gain a 1/4' to 1/2" with heavy duty factory packs. If you springs aren't sagged out, add one or two rear springs into them. This will get you about 2" to 3" of lift. Then ad one or two in the back, and a block an inch or so tall.I do this to all my plow trucks. Gives it a bit more height, and helps with the weight of the plow.
« Reply #7 on: November 21, 2011, 06:25:16 pm »
thanks i can just buy a lift its not that expensive i was just thinking some of them chevys had straight or positivly arched front springs but i must be wrong
Offline Engineer
« Reply #8 on: November 27, 2011, 12:24:38 pm »
If you are wanting 2~3" it will probably be less headache in the long run to go aftermarket.
JMHO.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
