Author Topic: problem with "rebuilt" TH350 tranny  (Read 11847 times)
Offline sbx22
  • 1974 1/2 ton 350 sbc
« on: November 22, 2011, 10:46:28 pm »
'74 1/2 ton 2wd long bed with TH350 tranny. I've replaced the whole drivetrain due to previous issues and problems. Done with swapping motor as well as a rebuilt tranny. I start the truck up, do the proper break in procedures for the motor, drive it around the block, come back, let it sit. Moments later, I see a pool of red fluid under my truck (tranny fluid). I trace it, and it's coming from the driver's side border of the tranny pan. Could it be that the shop that rebuilt the tranny "incorrectly" installed the gasket? Sheesh, I thought I'd be driving it by now. Am I missing something here? I slightly tightened up the bolts more, but still leaking. I've bought a felpro gasket so that I can take it apart this weekend. Any tips or suggestions appreciated.
Offline snibook7537
  • Vince Ziolkowski
Re: problem with "rebuilt" TH350 tranny
« Reply #1 on: November 23, 2011, 10:23:08 pm »
I don't know about you but I'd take it back and complain, kind of would make me leery about trusting that transmission at all.
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
Offline firefighter
« Reply #2 on: November 23, 2011, 10:43:25 pm »
I can't think of anything that would make it leak there besides a faulty gasket or pressure being built up inside the transmission body, and that should not be.
Offline 69byrd
  • Haulin!
« Reply #3 on: November 24, 2011, 10:19:52 am »
I agree I would make the builder fix it.
Offline sbx22
« Reply #4 on: November 24, 2011, 07:37:46 pm »
I may just have to call the guy up. I'm going to attempt to change the gasket or re-torque the bolts to specs and see how it goes this weekend. If that doesn't work, then he's going to get a call. I'd hate to take the tranny back out.
« Reply #5 on: November 24, 2011, 09:18:35 pm »
Are you sure it's not just running across there? It's not wet anywhere else?
Offline sbx22
Tranny leak, found it!
« Reply #6 on: January 19, 2012, 01:32:20 pm »
But this isn't coming from the gasket. I've had the gasket switched already, and now, I'm 99% this is where it is coming from. I don't know what this part of the tranny is called, the part where it shifts. See red arrow below. I believe this is the culprit. I've never taken apart a tranny before. Can anyone tell me if this part has a rubber gasket that may be bad or something?
Offline 87454westernhauler
« Reply #7 on: January 19, 2012, 04:18:30 pm »
would that have an o-ring gasket??
79 gmc c20 350 th350
78 k1500 4x4 350 th350
« Reply #8 on: January 19, 2012, 08:49:21 pm »
Perhaps the builder never installed the seal(?).
The "shift shaft seal" is a press-fit rubber lip seal moulded into a steel collar.  It presses into the case over the shaft from outside the trans.  You can replace the seal w/o removing the pan if you use a special tool like the one pictured from Napa (P/N:  BK 7769250) for under $10.  It should be generally available from most parts stores under various brand names.  All you have to do is remove the external lever then screw the black puller into the old seal, tighten the center screw to remove the old seal, then drive the new seal in with the silver tool.  It's an easy fix as long as the shaft & case aren't too worn.
The question is:  Why not drive the vehicle to the trans builder and have him change the seal w/o pulling the trans back out?
Offline sbx22
« Reply #9 on: January 19, 2012, 11:52:37 pm »
I'm not even thinking about taking the tranny out, that would suck if I had to. Anyway, if it's an easy fix, i'd rather do it myself on the weekend. From the looks of it, I won't have to take the tranny out, just mess with the shifting part while under the truck. Plus, I've been working so much that I won't have time to drive there and back (picked this tranny 2 hours away from me). Thanks for all the helpful information, leads me to a good direction.
« Reply #11 on: January 22, 2012, 10:22:46 am »
You can change the shift shaft seal in the truck. I have the tool pictured which is nice but a pick tool and pocket screwdriver and a socket can do the trick as well.
Offline sbx22
« Reply #12 on: January 22, 2012, 08:47:06 pm »
I got it fixed this weekend yah! no leaking so far... knock on wood.
« Reply #13 on: January 23, 2012, 07:55:25 am »
     Glad to hear you got it fixed and hopefully it wasn't too hard.
