Author Topic: how many turns???  (Read 3656 times)
Offline 87swb
how many turns???
« on: November 29, 2011, 07:35:16 pm »
hey all, i know its been a long time since i posted anything. i 've been having a ticking problem lately and i adjusted my valves to 1/2 turn but still heard it, so i went 1 full turn and now i don't think i can hear it or it's a lot quiter. i've done heard 1/4, 1/2, 3/4 and1 full turn. is 1 turn too much? i also noticed a couple of rockers weren't oiling. what can i do about this?  this is on my 87 305 TBI with prolly 120-130 thousand miles on it. thanks
Re: how many turns???
« Reply #1 on: November 29, 2011, 07:40:21 pm »
Did you check your oil level? What's your oil pressure? How are you adjusting them? Are you saying zero lash from the base circle of the cam + 1/2 turn?
Offline 87swb
« Reply #2 on: November 29, 2011, 07:50:18 pm »
the oil level is at the full mark. today with the motor warmed up, the truck in park, the pressure will hang around 30 maybe a lil below it. i adjust with the motor warmed up, loosen off the rocker nut till it clacks, then tighten till it stops, then from there i went 1 full turn in 1/4 increments.
Offline 87swb
« Reply #3 on: December 01, 2011, 06:56:44 pm »
i guess i'll just go on a hunch and say its alright then...
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #4 on: December 02, 2011, 08:24:43 am »
I always thought about 3/4 should be sufficient.
