Author Topic: manual to auto swap  (Read 9486 times)
Offline 1980 gold
manual to auto swap
« on: November 30, 2011, 05:08:05 pm »
i ended up getting a real good deal on a turbo 400 to swap into my 87 swb. the guy gave me the adapter for my 208 case, flywheel, converter, dipstick, crossmember, mounts etc $200. i'm not gonna column shift it right away for now i bought the b&m unimatic floor shifter. if anyone hase pics of this one mounted can you post em so i can see approximately where it will fit best on the floor. also if anyone knows how i do the kickdown cable with the tbi 350? and if you have pics that would be great.
Re: manual to auto swap
« Reply #1 on: December 12, 2011, 08:12:55 pm »
TH400 kick down is controlled by a solenoid.  I am not really sure what else you are asking?
Offline roger97338
« Reply #2 on: December 26, 2011, 03:29:19 am »
I converted from a manual to a TH-400 too. I couldn't easily find the factory kickdown parts when I did the swap, so I opted for this Lokar unit. So far, so good.
http://www.lokar.com/product-pgs/throttlecables-kickdowns/tc-kd-pgs/th400kd.html
Offline 1980 gold
« Reply #3 on: December 26, 2011, 03:34:35 pm »
hey thanks
Offline jdl71
« Reply #4 on: December 26, 2011, 06:30:49 pm »
Are there different versions of the TH400? What exactly does this lokar kit do? My TH400 kickdown runs off manifold vacuum to a solenoid on the side of the transmission. The only parts you should need would be a vacuum hose with a bit of steel tubing and maybe a tee for the manifold.
« Reply #5 on: December 26, 2011, 10:10:54 pm »
The kickdown on a TH400 is an electrical switch on the accelerator pedal.
Offline fitz
« Reply #6 on: December 27, 2011, 06:57:15 am »
If your trucks an 87 with a TBI motor I believe the kickdown is  controlled by the computer. Maybe you can retro fit the gas pedal switch like Capt and Blazing said.
« Reply #7 on: December 28, 2011, 12:25:29 am »
For the detent use GM 1242101 or equivalent.  The factory under-dash brackets and accelerator pedal arm should be compatible for a bolt-in, wire 'n drive (plug-n-play) experience.  ;)
Offline jdl71
« Reply #8 on: December 28, 2011, 04:59:47 pm »
Yeah, not sure what I was thinking. Vacuum modulator is what I meant.
Offline 1980 gold
« Reply #9 on: January 01, 2012, 09:46:39 pm »
thanks for the input guys haven't been on the computer in a few days
Offline johnhood
  • Rough Country Suspension
« Reply #10 on: January 14, 2012, 08:39:50 pm »
im not understanding this??? somebody fill me in my turbo 400 came out of an 87and all my kickdown is ran off of vacuum from the modulator off the side of the transmission when i first put the transmission in it wouldnt kickdown i hooked up the vacuum hose it kicked down what year transmission are you running?
1985 Chevrolet Custom Deluxe 400 Small Block TH400/NP208  6inch Rough Country Lift
Offline 1980 gold
« Reply #11 on: January 15, 2012, 05:29:16 pm »
mine was from an 86 military blazer that had a diesel
Offline johnhood
« Reply #12 on: January 16, 2012, 02:23:18 pm »
oh ok mine came out of a 3/4 ton 4wd truck w/ tbi
