Author Topic: 77 C/10 No Dash Lights  (Read 9170 times)
Offline Firebreather
« on: December 12, 2011, 03:32:31 pm »
Help! No dash lights, I replaced light switch, checked fuse, replaced inst cluster bulbs, and still no glow...................
Re: 77 C/10 No Dash Lights
« Reply #1 on: December 12, 2011, 04:18:33 pm »
     Did you check your printed circuit board to see if the connection for the dash lights got cut or broke somehow ?  Check to see if you have power at the dash lights and work your way back to fuse block.
« Reply #2 on: December 12, 2011, 04:41:05 pm »
Did they work before, what changed?
« Reply #3 on: December 12, 2011, 06:14:47 pm »
Don't forget the ground.
« Reply #4 on: December 12, 2011, 07:14:25 pm »
Thanks for the help, I will try tomorrow. They did not work before, the kid before me did a GREAT job of taking things apart and cutting wires.
I don't think he missed a screw or a wire........... ???
« Reply #5 on: December 12, 2011, 07:59:38 pm »
Did you adjust the dimmer?
« Reply #6 on: December 13, 2011, 01:21:36 pm »
Yes, I did try the dimmer, I tried the obvious first. :)
