Author Topic: Should I get a new spindle?  (Read 9574 times)
Offline frotosride
    • WFO CONCEPTS
« on: December 27, 2011, 07:56:44 pm »
Ya I didnt want to suggest hitting the spindle, someone out there would have used a regular hammer.
currently, due to frustration i resemble this remark. No i didn't actually hit the spindle with a hammer ( i know a machined surface when i see one..most of the time). I actually hit the spindle nuts and locking washer with a hammer and in the process nicked the spindle. It's not a big nick not even 2mm in either direction and less than one in depth. I'm thinking i can buff it out since it is right on a high side. Any thoughts on this working and if not, any good thoughts on shopping for a new one? Thanks in asvance for tha advice.
Re: Should I get a new spindle?
« Reply #1 on: December 27, 2011, 09:10:01 pm »
Depends on where the nick is.  Often times nicks can be dressed out.  Can you post a picture of it?
« Reply #2 on: December 27, 2011, 09:12:51 pm »
If a bearing race goes over it, no problem.  If a bearing rides on it then replace it.  I am not that familiar with the 4x4 front ends, post a picture...
Offline frotosride
    • WFO CONCEPTS
« Reply #3 on: December 27, 2011, 09:19:04 pm »
Putting a dip in and then taking the pic brb..
Offline frotosride
    • WFO CONCEPTS
« Reply #4 on: December 27, 2011, 09:43:35 pm »
 http://www.resizepictures.com/view.php?id=586203
Good advice after taking the pic I took the old outer bearing out of the rotor and the bearing race cobers it. So it looks like it just needs a little emery cloth and she will be good to go.
« Reply #5 on: December 27, 2011, 09:56:12 pm »
If you were down in the radius I'd be concerned.  I think it will dress out nicely.
« Reply #6 on: December 27, 2011, 09:58:05 pm »
X2 and you are good to go...
Offline frotosride
    • WFO CONCEPTS
« Reply #7 on: December 27, 2011, 10:03:56 pm »
Thanks guys...now one more thing on the to-do-list. Getting a dead blow as well
« Reply #8 on: December 28, 2011, 11:55:50 am »
     This is a must while working on vehicles.  Buy a good quality one, it will be money well spent over the years.
Offline frotosride
    • WFO CONCEPTS
« Reply #9 on: December 30, 2011, 01:01:36 pm »
Yeah, you'd think that I'd have one as much as i worked with them when i was still attached to a sub.. guess shore duty makes you soft minded.
