Author Topic: Frame cracks & preventative reinforcement  (Read 10726 times)
Offline bd
« on: December 28, 2011, 02:20:52 pm »
My 87 R10 has been plagued with frame cracks propagating from the rear shock mount holes and steering gear mount (classic tearout of the frame rail).  All are in-process of repair.  Does anyone know if cracking issues commonly invade the rails inboard of the upper A-frame mounts, below the engine mounts?  I am considering adding the factory inboard frame reinforcements from a 3/4-ton.  Pros/cons/other thoughts/suggestions?
Re: Frame cracks & preventative reinforcement
« Reply #1 on: December 28, 2011, 02:45:12 pm »
Reinforcement is always a good idea IMO.  Maybe it is just me but when GM went to the 1981 and lightened everything up I am seeing more frame cracking than the 73-79 era.
Offline bd
« Reply #2 on: December 28, 2011, 03:10:34 pm »
The frames are definitely under-engineered; designed to be disposable.
« Reply #3 on: December 28, 2011, 07:47:46 pm »
     Unfortunately the newer vehicles are all this way, and they newer they get the more disposable they become.
Offline bd
« Reply #4 on: December 28, 2011, 08:03:48 pm »
Well... As disappointing as it is, I guess it gives guys like us something to do....
Do you think I'll gain anything by adding the 3/4-ton reinforcement inside the rail?
« Reply #5 on: December 28, 2011, 08:14:51 pm »
     Reinforcement of any kind should help.
« Reply #6 on: December 28, 2011, 08:46:29 pm »
This,
 but the nice thing about these frames is they twisted and turned and got somewhat back to normal. The newer designs...once you exceed suspension travel, be prepared. I would just beef up where you need to
Offline bd
« Reply #7 on: December 29, 2011, 08:09:35 pm »
Thanks for your input, Boys!
