Wheels & Tires
aluminum rim polish Need feed back
Topic: aluminum rim polish Need feed back (Read 12561 times)
84chevysilverado
December 29, 2011, 02:12:04 pm »
What is the best aluminum wheel polish out there from your expierience? I have aluminum rims on my c 10 and they just dont have the shine they used to I have tried mothers aluminum wax with a power ball and nothing changes. need some advice thanks Marc
bd
Re: aluminum rim polish Need feed back
December 29, 2011, 02:19:05 pm »
I use Semichrome metal polish. But shop around - it's expensive.
74GMC
December 29, 2011, 04:01:21 pm »
Try Mothers Billet, Red metal lid on it clear plastic bottom. It's a good polish for aluminum, brass, silver, and many other metals. I have aluminum mags for my truck and they need a major polishing done. It just takes time.
"Nothing Beats a Chev"
Isaac3384
December 30, 2011, 09:19:01 am »
This^
Mothers is the way to go for polish. I use it on everything I have that's aluminum and it gives it a mirror-like finish. I've never tried using the 'ball', I just apply by hand, keep rubbing until it turns black, then move on to the next area... I'll usually apply it twice to each object being polished...
muddpuppy01
December 30, 2011, 03:42:13 pm »
are you using the paste or the liquid with the ball. how bad is the oxidation. you dont want to rub it dry with the polish. try misting some water on them while using the ball. if its really bad oxidation try using the scratch remover first, then polish liquid, then the billet polish.
zieg85
December 30, 2011, 05:33:16 pm »
http://forum.73-87chevytrucks.com/smforum/index.php/topic,17252.msg136872.html#msg136872
is a good read for what you are doing
84chevysilverado
December 31, 2011, 08:56:44 am »
well my rims are only 3 years old and once i polish them they look great my only issue is i let the truck sit for 2 weeks and i got puddles in my rim. i have tried everything to get those water stains out with no luck any ideas for that? thanks marc
DustyRusty
January 01, 2012, 02:00:37 am »
Other than repolishing your rims to get rid of the water spots, use some white vinegar on a rag to remove the spots. I use it on stainless w/ positive results.
Rusty
1975 K-10 SWB Fleetside - 350/SM465/NP205/D44F 12-boltR, 3.73 gears. Original owner.
Customized by rust.
mattgood
January 31, 2012, 08:59:46 pm »
I have a power ball and it works ok with mothers aluminum. But there is an all around metal polish called blue magic that works better in my opinion. I currently have some old aluminum american racing mags that I have polished with this and it worked good.
Don't let your water melon.
1980c10
January 31, 2012, 10:08:47 pm »
I also stopped using mothers polish when I dicovered "Blue Magic" It works a whole lot better. My rims and a lot of my engine are polished aluminum as well as my semi truck has polished wheels tanks and tool box. So I have tried evrything I can come across. I also use a cheap metal polish kit from harbor freight it has a bunch of differant shaped and size buffing wheels or heads that attach to a drill or just a wool wheel on a buffer for the larger areas. Otherwise for hand application I use the eagle one wadding but the machine makes for a lot nicer and quicker shine.
You can always sand and buff your shine back into just about any polished wheel if needed when they are in really bad shape.
73k5
February 05, 2012, 09:04:43 pm »
http://www.thunderracing.com/shop-by/category/Oils-and-Fluids/Shop-Use/-Way-2EZ-Polish_531.html
A guy here local makes this stuff and its awsome.....
http://www.street-dreams.us/groupcategoriespage.php?Group=Chrome+%26+Billet+Accessories
I belive this guy ^^^ has it in stock.. If ya wanna order a bottle... You will not be disapointed...
69byrd
Haulin!
February 07, 2012, 08:45:44 am »
I think that the mothers billet polish is the best out there. I have used it on some really dull wheels and made them look new with alittle bit of effort. As far as how much shine you get and how long it will last depends on what brand wheel you have. Some wheels just seem to be of a better quality of aluminum.
305chevy c-10
May 22, 2012, 09:31:49 pm »
i put white lighting on mine to clean them because the PO never cleaned them they were orange with clay .the acid turned them super white then i used NEVER DULL from walmart it workes but u have to rub alot .we the PO saw then again he thought i replaced them with new ones
Heartbeat of America yesterday's cheverolet
18T5C10
Wheels & Tires
