Author Topic: Distributor question  (Read 10513 times)
Offline Kolage
« on: December 31, 2011, 02:38:06 pm »
I installed a new msd streetfire hei dizzy in my truck and was wondering what the red wire that comes off the yellow one was for. I keep getting a small clatter under heavy acceleration sometimes no matter how much I advance or retard the distributor.
« Last Edit: January 31, 2012, 04:45:35 pm by Captkaos »
Offline Kolage
Re: Distributor question
« Reply #1 on: December 31, 2011, 02:38:32 pm »
Sorry about the size of the picture
Offline jaredts
« Reply #2 on: December 31, 2011, 03:10:23 pm »
According to the instructions I just googled, the heavy red wire goes to a full time 12v source, and the smaller red wire goes to a keyed source, like an accessory spot on the fusebox.  I don't see a picture.
« Reply #3 on: January 01, 2012, 12:48:52 pm »
     Your pic did not work, and jaredts is correct as far as the instructions go.
Offline Marvan c10
« Reply #4 on: January 30, 2012, 09:14:40 pm »
 1980 c 10 2 whl dr 305
we have changed the coil and are still hearing an arcing noise- any ideas?
While we're speeding through life, we miss the chance to get a good look at the road we're on.
« Reply #5 on: January 31, 2012, 07:55:15 am »
     Marvan, start the truck in the dark and look for sparking to see if it is outside or not.  If you can not see it, see if you can pin point the area it is coming from and report back.
     In other machines that I work on for work, we use spark type wires to run burners and such, even the smaller 24 volt pilot light assy's can short out through a wire sheath and create the tick, ticking noise if they get too close to a metal source, even if they are brand new.
« Reply #6 on: January 31, 2012, 11:23:17 am »
kol your using gmail as your picture host so you have to be logged into your email to see it. host it on photobucket or upload it to here
Offline jaredts
« Reply #7 on: January 31, 2012, 07:43:44 pm »
Under heavy acceleration?  Are you sure that isn't pinging?  Have you rechecked your timing since installing this distributor?  I know you said you have tried to advance and retard, but if you are a tooth off you'd have to turn it quite a bit.  Do you know your initial timing?  I may have mis-spoken as well about the wire.  If this is a hei replacement, it should be plug and play just like oem with a b+ connector like the one you took out.  There shouldn't be any wiring other than plugging in the module and the 12v source.
« Reply #8 on: January 31, 2012, 08:30:34 pm »
Quote
Don't understand what you are saying here but it sounds like you are describing pinging.
