Author Topic: Caster /Camber?  (Read 12030 times)
Powerglide350
  • Guest
Caster /Camber?
« on: July 08, 2002, 11:15:00 am »
I went to Sears for an Alignment on My 87 Blazer K5 4X4 They say they cannot adjust the camber/Caster but it is out. I looked under the truck and I can't figure out how you would either. Am I missing something?
oscarone
  • Guest
alignment
« Reply #1 on: July 25, 2002, 01:37:00 am »
I have 77 K10 p/u with Dana 44 front axle.  I don't know if your truck would be the same.  On the 4x4's the only adjustment is toe-in/out.
Offline 79GMC4x4
Re: alignment
« Reply #2 on: July 28, 2002, 08:56:00 am »
New ball joints?
'79 GMC shortbed 454 th400 14 bolt FF NP205 Dana 60
Re: alignment
« Reply #3 on: July 28, 2002, 08:08:00 pm »
If it is that far out, you can compensate with shims.
Offline 84 silverado
caster/camber
« Reply #4 on: July 29, 2002, 07:20:00 pm »
as stated before, the ONLY adjustment you can make on a 4x4 is toe in/out. The front axle is a straight axle so the other two are set by the position/starightness of the axle.
Offline 79GMC4x4
Re: caster/camber
« Reply #5 on: August 07, 2002, 11:06:00 am »
Vile Zambonie is right about caster and shims, but no, camber cannot change on a straight axle.
