Author Topic: Suburban seat, question  (Read 23978 times)
Offline Elpresidente
« on: January 08, 2012, 11:53:38 am »
Is the 2nd or 3rd row bench seat on a suburban the same as the front seat on a C/K truck?
'82 Chev Scottsdale
Proud to be Canadian \m/
Offline PromiseKeeper
Re: Suburban seat, question
« Reply #1 on: January 08, 2012, 12:10:45 pm »
cant wait to hear more...was wondering the same thing
Offline 87454westernhauler
« Reply #2 on: January 08, 2012, 12:45:58 pm »
i used the back seat out of my dads old 79 c3500 in my 80 c10 and it worked, but where u mount the seat, the mounts are higher so it wound up sitting about 3 inchs higher than the stock seat. but it still works.
79 gmc c20 350 th350
78 k1500 4x4 350 th350
« Reply #3 on: January 08, 2012, 01:45:23 pm »
No, second and third row are different.
« Reply #4 on: January 08, 2012, 02:31:02 pm »
But could still be used as a front seat, or is it really so different that theres no way it will work?
'82 Chev Scottsdale
« Reply #5 on: January 08, 2012, 03:18:56 pm »
The far back seat isn't as wide.  The middle seat is a 80/20 and hinged, the back and seat bottom are not even attached.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #6 on: January 08, 2012, 09:09:27 pm »
my 3rd row in my 91 sub 2500V is completely different than a cab bench.  There aren't mounted to sliding brackets...they just hook in place and a lever in the back makes it so you can remove the rear seat.  Wouldn't work at all for a cab bench. And, as stated, they are not as wide and the floor is higher, so, by putting a 3rd row seat up front, it will sit way low.
Offline heavychevy91
  • '86 Chevy K20
« Reply #7 on: January 10, 2012, 05:59:22 pm »
Would the 3rd row be similar to a blazer seat?
« Reply #8 on: January 11, 2012, 05:52:15 pm »
The second row on a Suburban is specific to that bodystyle.  The front seat of a suburban is the same as the front of a crew cab, and the same as a non tilting style of a pickup.  The third row is the same as a Blazer.
Offline Hollowman
« Reply #9 on: February 18, 2012, 06:21:24 am »
My Suburban never had the third row seat, is it a problem to add it, if I just find it from another Suburban or Blazer? Especially thinking about the belts.
Chevrolet Suburban '80, 307/350
Chevrolet van '83, 6,2D/700
Chevrolet Corvette '71, 496/400
« Reply #10 on: February 18, 2012, 09:27:19 am »
Adding a factory 3rd row may be a bit of work.  The floor structure that the seat latches into is spot welded into the floor.  I suppose you could modify it to clamp in but safety and ease of removal would be two points to consider.
« Reply #11 on: February 22, 2012, 05:27:02 pm »
You have to cut out and weld in the floor support/catches to put the third row in.
