Author Topic: Turning Radius Grew after Installing 3" Suspension lift  (Read 19298 times)
Offline dmiller2222
« on: January 12, 2012, 02:00:50 pm »
I installed a 3" suspension lift on my 1979 K-10 and it seems like my turning radius is not as tight as it use to be. What can I do to correct this and get it back to the stock turning radius?  Everything else is perfect; ride, wheel alignment etc., just a wider turning radius.
Thanks for the help,
David
Offline firefighter
Re: Turning Radius Grew after Installing 3" Suspension lift
« Reply #1 on: January 12, 2012, 03:56:26 pm »
Did you change any tire / wheel items too, or just added 3" of suspension lift?
By adding 3" of suspension lift, you slightly change the angle of the drag link (I think that's what it's called) going to the steering arm. The more you raise the steering gear box without raising the steering arm, the less movement you'll have at the tire I believe.
A person wants to keep the drag link as flat as it was when stock to keep the best steering geometry.
At least this is my thought.
Anyone else ??
« Reply #2 on: January 13, 2012, 06:55:42 am »
Anyone else ??
    Correct, I assume you used your original steering arm and did not get a raised steering arm with the lift ?
Offline dmiller2222
« Reply #3 on: January 13, 2012, 10:13:35 am »
Thanks for the info.
Correct, I did NOT get a raised steering arm with the kit. Do I need a raised steering arm or would a drop pitman work?  Do you have any suggestions on Manufacturer or part #?
Thanks,
David
Offline 74k20
« Reply #4 on: January 13, 2012, 02:11:58 pm »
I thought you only needed a dropped steering arm with a 4" lift?
Offline dmiller2222
« Reply #5 on: January 13, 2012, 03:54:33 pm »
That's what I had heard as well; like I said it drives a good as new, no bumpsteer, perfectly smooth. Just a noticeably larger turning radius.
Offline 74k20
« Reply #6 on: January 13, 2012, 05:16:54 pm »
I did a 2.5" Skyjacker lift, then added a small spacer in front = 3.25" lift.  Not sure I noticed a turning radius difference or not, as it's always been bad compared to my daily SUV.  I do tend to wander all over the road however, but think that's because of the tall side wall tires.  I replaced my drag link hoping it would help, but it didn't.  Wondering if changing to a drop link would also help me, hence why I'm following this thread.
« Reply #7 on: January 13, 2012, 08:32:05 pm »
Any lift will affect the turning radius. 4" is when they recommend a dropped arm as that's when it gets noticeably worse. If you notice the radius is probably close to what it was stock a little less, to the left. To the right its is probably allot worse than it was stock. You can adjust the drag link to make them equal but it will still be a wider radius than stock. Your steering wheel is probably not strait any more either correct?
Wider tires will affect it a small amount too as they tend to slide across the surface a bit more than stock tires. The wider the tire the less weight per square in you have on your contact patch.
74K20: Your wondering problem is most likely due to the use of a spacer in between your springs, and axle. Shouldn't use any type of spacer / block in the front end, dangerous. Most states they are illegal.
« Reply #8 on: January 13, 2012, 09:29:38 pm »
Correct drag link length and raised steering arm as well as a proper alignment will correct your toe out on turns provided nothing is bent or out of proportion.
Offline dmiller2222
« Reply #9 on: January 13, 2012, 09:51:32 pm »
Thanks for the help guys.
Blazin: The steering wheel alignment is perfect. I aligned the vehicle shortly after installing the lift. I have not checked the diff in Turning radius from one side to the next.  Will do and let u know.
David
« Reply #10 on: January 13, 2012, 10:01:38 pm »
Hmm, usually the wheel will be off if the axle is moved farther away from the frame, and the drag link isn't adjusted or a dropped arm installed.
« Reply #11 on: January 14, 2012, 07:12:25 am »
     If he had a shop do the alignment, they might have straightened the steering wheel for him, most good shops will.
« Reply #12 on: January 14, 2012, 12:46:01 pm »
The drag link adjustment doesn't change total toe but it will change steering wheel position. If you don't compensate for the length of the drag link and the angle your turning radius will be affected.
Offline dmiller2222
« Reply #13 on: January 16, 2012, 10:59:40 am »
So; I assume if a lowered pitman/raised steering arm is required for a 4-6" lift then the parts will work ok on a 3"lift and get my radius back to norm?
« Reply #14 on: January 16, 2012, 09:35:46 pm »
I would just do the steering arm.
