Author Topic: engine storage  (Read 10337 times)
Offline 305chevy c-10
engine storage
« on: January 14, 2012, 10:10:12 am »
before  i left the machine shop,the machinish told me not to put my motor togather until it gonna be put in the truck in a day or so .he said if i put it togather and say let it sit for months the assembly lube would just drain into the oil pan and on start up it would be metal on metal with no lube.now heres what intresting to me. the guy that is gonna assemble my engine said all that is true if u use assembly lube ;however if u use vasoline to assemble it it can sit alot longer but u have to watch out for dust .he said the vasoline wont drain off the cam and etc.when i was in his shop i notice he had a few engines on stands being built .i was just wondering has anyone ever heard of such a thing .i mean to me it makes sense ,but im no engine builder
Heartbeat of America yesterday's cheverolet
18T5C10
Re: engine storage
« Reply #1 on: January 14, 2012, 12:40:54 pm »
That's ridiculous. Use bearing guard or EOS Engine Oil Suppliment. After assembly prime the oiling system. If it's going to sit for a long period of time just keep it in a humidity controlled environment and turn it over once in a while.
Re: engine storage
« Reply #2 on: January 14, 2012, 03:19:04 pm »
may i was not completely clear on letting it sit.i mean that it would be put togather on a stand  and stored never even ran for break in yet( no fluids added ) .by turn it over u mean spin it with my hand every so often
18T5C10
Re: engine storage
« Reply #3 on: January 14, 2012, 08:16:15 pm »
I have seen vasoline used many times. Also had a couple motors one with assembly lube, the other with vasoline sit for several months before installing them. Used an electric drill to prime them before start up, they were just fine.
Re: engine storage
« Reply #4 on: January 15, 2012, 12:25:05 am »
Maybe you should clarify what YOU mean by letting it sit? You're going to build an engine and then it's going to sit for how long and where? You can rotate the crankshaft is what I meant by turn it over.
Re: engine storage
« Reply #5 on: January 15, 2012, 11:24:53 am »
it will be in a utility house on a stand in a plastic engine bag for maybe 6-7 months .i'm  just trying to figure out the best way to go .i have a guy that can put it togather for 300.00 ,but he really too tied up with his other race cars to put it in .or its another guy who i can let build it and put it in or just put it in .trying to see if building it and letting it sit would be a bad idea .i have a lot of money in this thing .thanks for yall advice will post pics when it done  ;D
18T5C10
Offline HAULIN IT
Re: engine storage
« Reply #6 on: January 15, 2012, 08:14:02 pm »
I'm not sure what a "utility house" is or if it's dry, damp, warm, ect. The most important part of this is what Vile mentioned...Prime the oiling system! You have a bare metal block that was cleaned of all of it's oil...it will rust VERY fast. If you don't prime it, the inside of the oil passages will rust & when you start the engine, all of the rusty "mud" will go through your new, clean engine plugging up & scratching everything.
To do this you'll use a tool in a drill & spin the oil pump through the distributor hole. Turning over the engine a 1/4 turn now & then would not be a bad idea. I would leave the rocker arms all loose also.
One thing I've done with core engines that I have no plan to use anytime soon is to FILL them with used oil. Tin covers over the exhaust ports & fill 'um up. I do this with differentials also. 10 gallons of new oil is cheap compared to taking it back apart. Just a thought, Lorne
Re: engine storage
« Reply #7 on: January 18, 2012, 06:44:22 pm »
ok i understand , but i dont understand .if there is no fluids in the motor but assembly lube or vaseline .what  is the reason for priming the oil pump if it will suck nothing.
18T5C10
Re: engine storage
« Reply #8 on: January 18, 2012, 08:57:48 pm »
Prior to cranking the motor you will fill it with oil and then prime the system this gets oil to all the components prior to cranking it.  If it is going to sit a while, fill it with some oil (cheap oil) and prime it and then cover/seal it.  I would recommend putting it in a stable environment.
Re: engine storage
« Reply #9 on: January 18, 2012, 09:47:46 pm »
ok i got now .my handi house is a dry place but i dont have heat or ac in it so in the summer its really hot in there until i open the doors and windows .thanks im gonna clean and wipe bores down with wd-40  and put it in a new bag until i get ready to assemble it .
18T5C10
Offline Stewart G Griffin
Re: engine storage
« Reply #10 on: January 18, 2012, 09:59:42 pm »
Another thing:  When you do prime it get the right tool----just the shaft is no good---some or all of the rockers may not get any oil even if you rotate the crank while you do this (need clarification/???).
The shaft with the disk and cylinder is the right one.
Post again just before you fire it up so we can get some clarification on this.
Re: engine storage
« Reply #11 on: January 19, 2012, 08:47:35 pm »
found this tool at summit racing. my is block taped off and painted now .tom i will give it a final wash with a gunk degreaser ,wipe bores and cam bearings  dry with shop towel re lube with wd-40 and let the rest air dry before i put it in bag
18T5C10
Offline HAULIN IT
Re: engine storage
« Reply #12 on: January 19, 2012, 09:50:46 pm »
We're not saying "Prime the oil pump."...Prime the oil system, as in: Fill the oil pan & run the pump with the tool that you posted to get the oil to be pushed through all of the internal passages. As mentioned, you should also do this again shortly before start-up. Lorne
Re: engine storage
« Reply #13 on: January 20, 2012, 11:21:25 am »
I am confused.  Is the motor assembled?  Is it going to be?
Re: engine storage
« Reply #14 on: January 20, 2012, 05:20:27 pm »
its not assembled yet .just trying to find out the do's and don'ts before i assemble it and let it sit on the stand for a few months (6-7)
18T5C10
