Author Topic: ID# for my motor  (Read 8990 times)
Offline Marvan c10
ID# for my motor
« on: January 15, 2012, 02:18:52 am »
 Where can I find the ID# for my motor ? It suppose to be a 350 but I'm starting to wonder. It was swapped out of a 85 k5 Blazer.
« Last Edit: January 15, 2012, 02:22:25 am by Marvan c10 »
While we're speeding through life, we miss the chance to get a good look at the road we're on.
Re: ID# for my motor
« Reply #1 on: January 15, 2012, 02:51:42 am »
On the block right behind the alternator is a pad that has the numbers stamped on it.  It will look similar to what is pictured.  From there we can determine what it is but if it is out of a 85 K5 it is more likely a 305.
Offline Marvan c10
« Reply #2 on: January 15, 2012, 11:34:46 pm »
 Thanks I'll check it out tomorrow, the game came on.
Offline Marvan c10
« Reply #3 on: January 16, 2012, 05:55:47 pm »
 I looked for it but didn't see any #s, My VIN# CCL44AZ115033
« Reply #4 on: January 17, 2012, 04:41:35 pm »
Its there. Clean the surface really good. You can also look at the back of the block, driver side of the distributor. Same deal, clean the surface really good. Its harder to get to.
« Reply #5 on: January 17, 2012, 04:43:27 pm »
The VIN is only going to tell you what year and engine came with the truck currently.
If there is nothing on the machined pad, it may have been decked or is really dirty.  You can also get the number off the back of the block where it meets the bellhousing, but it is hard to see on these trucks.
Offline Marvan c10
« Reply #6 on: January 17, 2012, 05:08:37 pm »
 So I will need to remove the alternator to see it ? And from the Vin# it's a
 ( C ) Chevrolet ( C ) 2wd  ( 4 ) cab and pick up box ( 4 ) 1/2 ton HD Susp ( A ) 1980 ( Z ) GMAD Freemont,Ca and last 6 # or the Serial #s. Did I get that right ?
« Reply #7 on: January 17, 2012, 05:16:17 pm »
C - Chevrolet
C - conventional Cab
L - 350-4bbl V8
4 - HD suspension
4 - Pickup
A - 1980
Z - Freemont assembly plant.
Build sequence # - 115033
Offline Marvan c10
« Reply #8 on: January 17, 2012, 05:37:43 pm »
 Thanks Cap ! I'll remove the alternator and get engine numbers.
« Reply #9 on: January 17, 2012, 08:02:52 pm »
Shouldnt need to remove alt, but it will be easier.
« Reply #10 on: January 18, 2012, 09:34:19 am »
     Use a flash light and mirror, you will have to clean the area very well and use a wire brush to get the dirt and such out of the scribed numbers in the block. (so you can actually see and read them)
Offline Marvan c10
« Reply #11 on: January 21, 2012, 03:49:33 pm »
 Engine #s V0521UFC/ CGF185220
« Reply #12 on: January 21, 2012, 07:18:25 pm »
http://www.nastyz28.com/sbchevy/sblock.php     So far I found v=plant=flint:  05=year:  21=day:  ufc=suffice engine code:
      I could find nothing that matched cgf185220
Offline Marvan c10
« Reply #13 on: January 21, 2012, 09:58:42 pm »
 Our mechanic at looked at it and that's what he gave me, to me it the F looks likes a backwards 7. But its CG--185220
Offline bigbird90650
« Reply #14 on: January 22, 2012, 01:01:54 am »
UFC=       Code    Year   CID    Vehicle   HP    RPO   Trans   Carb   Comments
                UFC       80     350    Truck    155   LT-9  TH 350  4-Brl    C 30, Van
                UFC       86     305    Truck    150   LE-9               4-Brl    C 10 & C 20
http://www.chevymania.com/   This is the website that I use most. Click on "parts ID" at the top then scroll down the list on the left side of page to "suffix codes". There is a pull down there so you scroll down the list to "UFC". Sorry it says that it's either a 305 or 350. Maybe getting the #'s off of the back of the block will narrow it down. The block casting #'s are on the driver's side rear of engine just behind the cyl head. You might need a little mirror to see back there. Good luck man.
73 Chevy C20 Custom. 350 engine Th350 trans. Stock for now. All original. Just bought it from the original owner's son.
