Author Topic: 1973 C20 stock suspension is WAY too rough. Help me!!!  (Read 27974 times)
Offline bigbird90650
« on: January 20, 2012, 11:30:38 pm »
Hi
I just got a 73 C20 and it rides WAY too rough for me. The rear is the worst. I'm not going to be hauling or towing very much at all. I want a softer ride. The rear leafs are 9 leaf. Can I remove a few leafs to soften things up? It has some airbags in the back that help it haul more I think. I haven't messed with them at all. I'm new to suspension so can you please be super detailed with your help. Thanks so much.
73 Chevy C20 Custom. 350 engine Th350 trans. Stock for now. All original. Just bought it from the original owner's son.
Online zieg85
Re: 1973 C20 stock suspension is WAY too rough. Help me!!!
« Reply #1 on: January 21, 2012, 12:00:12 am »
What kind of tires do you have.  I had a 72 K20.  It was a very harsh ride with the 7.50x16 tires on split rims.  Put some radial tires on it and it road a lot better.  Tires and shocks is where I would start.
« Reply #2 on: January 21, 2012, 12:10:32 am »
I have 33x12.50x16.5 BFG All Terrrains all the way around. Shocks are old. Rear suspension seems like it doesn't have springs at all. I know that a pickup always rides better with some weight in the bed but this thing is ROUGH. Can I remove some leafs out of the springs? Thanks
Offline 87454westernhauler
« Reply #3 on: January 21, 2012, 12:32:04 am »
i wonder if u remove the air bags first. i have a 74 c20 and it doesnt ride to bad with radials on it.
79 gmc c20 350 th350
78 k1500 4x4 350 th350
« Reply #4 on: January 21, 2012, 01:31:47 am »
No need to remove them, just lower the PSI. But with 9 leafs...
« Reply #5 on: January 21, 2012, 08:04:18 am »
I have 33x12.50x16.5 BFG All Terrrains all the way around.Shocks are old . Rear suspension seems like it doesn't have springs at all. I know that a pickup always rides better with some weight in the bed but this thing is ROUGH. Can I remove some leafs out of the springs? Thanks
     As Zieg said, replace your shocks first, bad shocks have no compression or damper motion on them and will act like you are riding on just your springs.
     After that make sure all your suspension mounts (spring bolts on eyelets and shackles ) are not over tightened, one mistake is over tightening the hardware and not allowing the suspension to flex properly.
« Last Edit: January 21, 2012, 08:07:27 am by bake74 »
« Reply #6 on: January 21, 2012, 10:41:20 am »
But with 9 leafs...what? Can I remove some? Should I remove some? Which ones do I remove? Can I put 1/2 ton leafs on the back of my truck? Will they fit? Thanks
Offline gto109
« Reply #7 on: January 21, 2012, 02:50:08 pm »
i have 3/4 ton rear leaves on my half ton.  I don't know if you will be able to fit the 33's with half ton springs though.
85 Scottsdale k-10 305 700r4,
86 Trans Am 305 350th
06 Dodge Ram daily driver
« Reply #8 on: January 21, 2012, 06:27:48 pm »
As everyone else stated I would start with the basics. Shocks, and or empty the bags.
33x12.5s on a C 20? They don't rub the fenders in the front when you turn??
« Last Edit: January 21, 2012, 06:34:58 pm by Blazin »
« Reply #9 on: January 21, 2012, 07:03:12 pm »
     Good catch Blazin.  ;D  I glossed right over the "c-20" part and assumed he meant that he had a k-10.
Offline Da67goatman
  • Burban
« Reply #10 on: January 21, 2012, 08:24:27 pm »
What pressure are you running in your tires?  not more than 30psi I hope.  You could remove leafs, but that reduces the ride height and load capacity, but you can pick up a block kit for like 35 bucks to bring it back up to proper height and the bags will bring the capacity back up.
<Pitcrew>
« Reply #11 on: January 22, 2012, 12:42:10 am »
Yeah they did rub until I trimmed the bottom of the fenders.
« Reply #12 on: January 22, 2012, 06:04:35 am »
     Ok now we have to see pics, have you posted any pics of your truck yet ?  Are you going for the 2wd with just a little taller stance ?
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #13 on: January 22, 2012, 09:43:19 am »
You can def remove some leafs, pretty easily, just seems like it would be easier to air-down the airbags first and try it then.  If you're talking about maybe putting 1/2 ton springs on it, you obviously arent worried about load capacity so you can just get rid of the bags altogether.
It doesn't matter if you put 1/4 ton springs on it, if those bags are aired up too much its going to be rough.  with the truck unloaded, and with proper springs in place, you should have zero pressure in the bags anyway when its unloaded.  Unless you plan on hauling more than 2500lbs in it, I dont really see a need for the bags anyway.   Somewhere around 2500lbs load makes mine sit about level.
Also since you have bigger tires, removing leafs will lower the truck, which may be bad.  Although you could also use that to level the truck out.
Mine has the 9 leafs and I love the way it rides, but admittedly it usually only sees smooth roads.  I hate speed bumps though, theyre bad on the back.
« Reply #14 on: January 22, 2012, 10:35:29 am »
33"s on a C20 and trimmed fenders with air helpers.... Did you buy it like this? Why such a setup? Everyone who told you to replace your shocks first is 100% right - use a good ride quality shock. As far as the rest of your setup I think everyone is curious as to why you have such a set up and what you use the truck for.
