502 in near future, trans question
Topic: 502 in near future, trans question (Read 12836 times)
choptop
Extended cab fanatic
January 24, 2012, 10:27:14 am »
I will soon be acquiring a 502 that is supposed to put out 650+ horsepower. Its going in my 76 choptop stepside instead of the 427 I was going to put in item. Question is what transmission should I build for it? I have Th350s, TH400s and 700R4s available. I don't think the 700 would live. Im pretty sure I'll have to use the 400 but was curious if anyone has had any luck running a th350 with this much hp/ tq. I know the th350 uses less horsepower which means more power to the ground. It will see most of its life as a ratrod cruiser but it will probably hit the track occasionally.
Re: 502 in near future, trans question
January 24, 2012, 01:48:37 pm »
700R4 if you plan to drive it.
Edahall
January 24, 2012, 04:43:46 pm »
It kind of depends on the use. For just track use, a 700R4works well because it has a low 1st gear and doesn't have as much parasitic loss. However, none of those transmissions you have listed except the TH400 is going to last with that kind of power. Have you considered the 4L80E?
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
LTZ C20
January 25, 2012, 11:28:46 pm »
My I also suggest a "lock-up" torque converter.
LTZ Cheyenne C20
choptop
January 28, 2012, 09:03:09 am »
This truck is basically gonna be a toy. Im gonna paint it, put a bench seat in it so both my girls can ride, and drive it. It will be beat on pretty good. My right foot isnt gonne behave very well with that much power unless I get to hammer it at the track on occassion. Ill probably go with the 400 because Ive learned that for what I wanna do the loss in horsepower isnt gonna make a difference. As far as the 4L80e, if Im gonna invest in a transmission that expensive, its going in to one of the trucks that will see more highway time than hotrodding. Thanks guys
January 28, 2012, 10:08:54 am »
Go with the 400 unless you can budget for the 4L80E
Da67goatman
Site Supporters
Burban
January 28, 2012, 12:06:38 pm »
I drove a 68 impala to prom that my dad's best friend built, runs mid 10s on a built 496 and turbo 350 on cheater slicks. Hasn't had any problems, except belts keep flying off under heavy accel lol. I would vote 700r4, but the turbo 350 could work if that's what you wanted.
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
heavychevy91
'86 Chevy K20
January 28, 2012, 12:20:02 pm »
Are you thinking of stock trans vs stock trans?
choptop
January 28, 2012, 11:34:07 pm »
Quote from: heavychevy91 on January 28, 2012, 12:20:02 pm
Definitely not. Im a firm believer that all of the components should be built to match, but if itI costs twice as much to build one to get the same benefits as the other, then I don't see the point. That's why I love bigblocks, it takes less $ to build the same horsepower out of a bigblock as it does a smallblock. . I don't think I could build a 650 hp smallblock for the $3k this 502 is gonna cost.
Last Edit: January 29, 2012, 12:22:54 pm by choptop
Engineer
January 29, 2012, 08:09:44 am »
TH400
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
zieg85
January 29, 2012, 09:43:23 am »
TH400 with maybe a 3.42 gear out back. With all that torque you will shred the tires and keep decent RPM's while cruising. Can't beat the torque of a big block...
roadrage41
January 29, 2012, 05:07:54 pm »
I dunno we put a stock 5.3 in a 454 SS and picked up 2/10th's
official go'fer/ broom pusher/ token fat guy of
www.yatesefi.com
choptop
February 04, 2012, 02:16:12 pm »
the 90 454 SS is one of my favorite trucks, but the 454 it came with was a poor excuse for a bigblock. The 5.3 was an upgrade for sure but a well built bigblock would have been better. just my opinion
Hollowman
February 07, 2012, 05:01:27 am »
I actually have an almost identical question. I want to put the GM Performance Ram-Jet 502 in my '80 Suburban.
1. What transmission? I was thinking TH-400, but it's just a guess. I want to cruise mostly in a comfortable way, but still not be too left behind "on the strip". Also, where to buy ready transmission for the engine? I live in Sweden, but will have to import it from overseas anyway I guess.
2. Ford 9"? I heard it's easier to deal with than the equivalent Chevy stuff, any ideas?
Thankful for any good info.
Chevrolet Suburban '80, 307/350
Chevrolet van '83, 6,2D/700
Chevrolet Corvette '71, 496/400
roadrage41
February 07, 2012, 09:47:23 am »
Choptop - its getting a 78mm turbonetics front mount setup as we speak.
Hollowman- we had to make some repairs on a Ramjet 502 over the summer, the fuel injection system for that thing is insane. My advice would simply be spend your money elsewhere, they were designed for boats, leave them in boats. There are many other prepackaged fuel injected big blocks out there. As far as a th400, did your burb not come with one?
www.yatesefi.com
