Author Topic: 91 suburban engine - does it have manual fuel pump capability?  (Read 3466 times)
Offline bigbird90650
« on: February 04, 2012, 10:56:42 am »
Hi
I found a really cheap 91 Suburban 350 engine for sale. I'm going to take the fuel injection off of it and put a carb. Does a 91 350 block have the manual fuel pump place on the block? Do these engines have roller cams? It's a running engine complete for $225. Thanks for your help.
« Last Edit: February 04, 2012, 06:12:16 pm by bigbird90650 »
73 Chevy C20 Custom. 350 engine Th350 trans. Stock for now. All original. Just bought it from the original owner's son.
Offline jaredts
I'm sure someone knows better than me, but I think it has a block off plate for the fuel pump but has no lobe on the cam to drive a fuel pump.  No big deal, just an electric pump and regulator fixes that.  I'm pretty sure its not roller anything.  Just hydraulic lifters, stamped rockers, and low flow (undesirable) heads.  I think you have to get to vortec era stuff for roller engines.
Re: 91 suburban engine - does it have manual fuel pump capability?
« Reply #2 on: February 04, 2012, 06:22:12 pm »
So the place for a manual pump is there but I would have to replace the cam?
« Reply #3 on: February 05, 2012, 10:00:21 am »
Some engines had block off plates. Some were cast solid in the area. You need to look at it to see.
