Author Topic: TBI idle and IAC steps  (Read 7139 times)
Offline chris989
« on: February 14, 2012, 02:58:45 pm »
Hello,
I have a 89 5.7 auto suburban 4x4.  I am using moates auto prom and data logging with Tuner pro.
Problem:  I can get my idle to go below 875 with zero IAC steps.  I am attempting to correct the idle with a new bin but can not get it ironed out.    I do notice that the data log always show i am in park,  even when i put it in gear,
Question.  Tunerpro is for many vehicles, (more sophisticated than my 89).  Does anyone know if my aldl should register park all the time or is my wire broke somewhere in my steering column causing my truck to always attempt to maintain idle speeds relative to park/neutral??
Thanks,
Chris
Re: TBI idle and IAC steps
« Reply #1 on: February 14, 2012, 07:27:05 pm »
     Well Chris, I do not have the answer's for you.  But I wanted to welcome you to the site, and be patient, someone will see this and reply.  Probably not until Wed. though.
Offline rsandusky
« Reply #2 on: February 15, 2012, 12:42:32 am »
Welcome Chris!!
First verify that you don't have any vacuum leaks. Vacuum leaks will cause a lean condition that is picked up by the oxygen sensor, the ecm then adds fuel to correct for the lean condition.
http://forum.73-87chevytrucks.com/smforum/index.php/topic,21039.0.html
« Reply #3 on: February 22, 2012, 05:59:53 pm »
Did you find an answer to this?
« Reply #4 on: February 22, 2012, 08:55:31 pm »
There is no transmission range switch. Check for vacuum leaks/tbi base gasket.
Offline frotosride
    • WFO CONCEPTS
« Reply #5 on: February 24, 2012, 07:53:43 pm »
Your issue with the IAC is because as I'm sure you know, inorder to set up IAC properly you have to have the butterfly's completly shut....and TBI's don't have an adjustment screw...or do they. If you notice on the throttle body there is a plug, I do believe on the left side. drill this out and you can adjust the butterfly's as you so desire.
« Reply #6 on: February 25, 2012, 09:58:42 am »
Do not mess with the screw - all you'll be doing is creating another reason to start chasing your tail. Fix the problem not the symptom.
Offline frotosride
    • WFO CONCEPTS
« Reply #7 on: February 25, 2012, 01:56:05 pm »
+1Very good point...maybe i should learn to read better before i reply to threads. I don't know why I was thinking that He was trying to get a newly preped engine running correctly when i replyed to this. But erase the screw from your memory or you will likely be chasing a new symptom....Thanks for the catch "Vile"
Offline DnStClr
« Reply #8 on: February 27, 2012, 06:54:11 pm »
My memory escapes me about the size of the socket you need to remove the iac unit- is it 1 1/8"? anyway- while you're checking for vacuum leaks, it's easy enough to take the iac out and give it a good cleaning with throttle body cleaner spray..
Don
87 Chevy Silverado
Offline DnStClr
« Reply #9 on: February 27, 2012, 07:11:22 pm »
If you want to see what your ecm is doing, you can download a free program called winALDL-
http://winaldl.joby.se/
but you'd need to spend a few bucks to make up a small cable.
Don
87 Chevy Silverado
