Author Topic: What's this sound?  (Read 5818 times)
Offline Shawn0331
    • My Blog
What's this sound?
« on: February 15, 2012, 12:27:14 pm »
I was told the ball joints are bad and need to be replaced along with the brakes. I'm doing that this weekend.
What I'm wondering though is, what is this sound?
The sound happens when I'm steering and barley moving.
It's the same sound that the truck makes if you steer all the way to the left/right.
I've attached an MP3 recording of me pulling into a parking lot and parking.
1987 Chevy V10 Silverado SWB 5.7 on 33x12.5's
http://www.shawnseeley.com
Offline 87454westernhauler
Re: What's this sound?
« Reply #1 on: February 15, 2012, 12:31:33 pm »
kind of sounds like the power steering pump sliping, but i do hear another sound like the front end needs greesed or the shocks need replaced maybe?????????
79 gmc c20 350 th350
78 k1500 4x4 350 th350
« Reply #2 on: February 15, 2012, 12:41:39 pm »
     I am at the office and the comp. that I am on right now does not have sound, but from what you described I would agree it sounds like the power steering pump.
     The pumps when turned all the way to left or right usually will strain if low on fluid, if you hear the same sound and you are not turned all the way out, most likely is steering pump.
Offline txchainsawgogi
« Reply #3 on: February 16, 2012, 12:22:10 am »
power steering pump…mine is going out too.
« Reply #4 on: February 16, 2012, 06:49:15 am »
     Just got to listen to it, power steering pump, you should flush the system also when you rebuild or replace.
« Reply #5 on: February 16, 2012, 07:40:34 am »
I would make sure that the belt is tight first.
Offline jaredts
« Reply #6 on: February 16, 2012, 10:38:12 pm »
Maybe I imagined it, but it sounds like scraping/grinding.  I had bad balljoints on an old monte carlo that sounded like that and it was the wheel hitting the knuckle.  If you have aftermarket wheels there could be very little clearance anyway.
