Author Topic: Changing 87GMC tbi to carb  (Read 3743 times)
Offline 1MCP7.3/87GMC
  • 75s my baby
« on: February 17, 2012, 10:23:24 pm »
Ok so what do I do about the return line? I need a way to feed back to the fuel pump any kits that auto zone/ oriley auto parts might have to do such a thing maybe with a built in regulator to keep the pressure at like 6-7 ibs of fuel need to know ASAP it's this weekends project and hadn't really thought it threw so now I have a new carb intake and the distributer stabbed on the motor that needs to run on Monday please advise
1984 Chevy Silverado 2wd swb (311hp 350) El Diablo Rojo
1975 Chevy Scottsdale 4wd swb  silver slug 350 tbi
1987 GMC Sierra 4wd lwb 350 stock replacement
Re: Changing 87GMC tbi to carb
« Reply #1 on: February 18, 2012, 06:05:01 am »
     I am pretty sure O'reilly's has a regulator that does what you are looking for.  Someone will chime in and tell you what they have done, I have seen other post on here with the same problem and the solutions, just can not find them right now.
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: February 19, 2012, 12:47:42 am »
The easiest and actual best way to do this would to make it a flow through system instead of the usual dead head commonly associated with carb setups. Get any regulator they have that is name brand Holley would be the goto but Professional Products should do the job as well. The only other thing you will need is a "T" fitting. connect the inlet to one side of the "T" fitting and the return to the other. Plumb the regulator to the 90 degree end of the regulator inlet. I say this is the best way because you will always have the appropriate pressure to keep the bowles full even undr full throttle pulls and it omits the immediate pressure drop in a dead headed system.
Offline frotosride
    • WFO CONCEPTS
« Reply #3 on: February 19, 2012, 12:51:14 am »
You can still do the dead headed system if you prefer but you will have to cap off the return line because it may allow fuel spilage under extreme braking or climbing steep grades. The other down side is the pump itself. If you are using the stock tbi pump then dead heading it may cause it to fail prematurely. This is one mmore reason i wouldn't reccomend a dead headed system unless you have pump designed for a carb set up.
