350 cam
4
Topic: 350 cam (Read 22678 times)
454Man
Why Race?
350 cam
February 21, 2012, 05:10:02 pm »
What's a good cam for a everyday 350? It may tow a jon boat down the line...
I'm looking at the edelbrok performer intake and cam kit idle to 5k. But id like to here some suggestions. I do want a little lope but mpgs would be little of a concern. Maybe in the 13+ mpgs but would like a lope when in gear at the stop light. I know its a compramise but...
Last Edit: February 21, 2012, 05:17:06 pm by 454Man
Re: 350 cam
February 21, 2012, 05:27:50 pm »
Why not keep the same one in it? Or is it not running?
454Man
Why Race?
Re: 350 cam
February 21, 2012, 05:45:59 pm »
I'm anout to get a truck with a locked up 305 and I'm gonna have a 350 built and want a good sounding/ performing cam
454Man
Why Race?
Re: 350 cam
February 21, 2012, 08:42:43 pm »
I've been looking at this cam
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=85&sb=2
Seems to be what I'm looking for. Lob center is good and lift is also. Again this will be a daily driver. Help guys remember I'm new to chevys:) will this work with stock heads and springs?
Jason S
Re: 350 cam
February 21, 2012, 10:11:10 pm »
According to the spec sheet you posted, the springs that Comp specifies are a bit stronger than stock and will necessitate machining to your cylinder heads (if stock).
Have you called Comp about the cam you are looking for?
Last Edit: February 21, 2012, 10:39:15 pm by Jason S
454Man
Why Race?
Re: 350 cam
February 21, 2012, 10:21:38 pm »
Thanks. I haven't called I figure you guys could point me in the right direction better than a tech/ salesman on the phone. I like to get others opinions and experiences before I talk to a salesman, so I can sound like I know what I'm talking about
454Man
Why Race?
Re: 350 cam
February 22, 2012, 10:38:46 am »
Well I called comp cams... he told me id have to upgrade heads, rocker arms, hedders, and so on.
not happenin. I'm gonna check on the ebrock idle to5k cam.
454Man
Why Race?
Re: 350 cam
February 22, 2012, 11:02:21 am »
K so I called ebrock and spoke with a tech... way more helpfull than comp. Anyhoo he suggested the 2103 cam for a little lope and power. Sounds like this may be it anyone have any suggestions?
1979C20
Kyle Taulton.
Re: 350 cam
February 22, 2012, 11:12:47 am »
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=72&sb=0
This is the cam I put in my truck. Its one of the extreme energy cams. I picked it up locally for 120 dollars, cam and lifters. It is the biggest cam I could get with stock valve train. Its got a nice lopey idle and quite a bit of power.
454Man
Why Race?
Re: 350 cam
February 22, 2012, 11:34:00 am »
Sweet! Thats more of a cam... How is the lope when in drive while pressing the brake?
1979C20
Kyle Taulton.
Re: 350 cam
February 22, 2012, 12:24:40 pm »
I have a manual transmission, so My idle sits around 400-500. It sounds real good. Its got a great rhythm to it. I'll see if I can find a video of it running somewhere.
454Man
Why Race?
Re: 350 cam
February 22, 2012, 01:27:17 pm »
Sweet! Thanks! Really appreciate it!
454Man
Why Race?
Re: 350 cam
February 23, 2012, 06:41:25 pm »
Did you ever get the video?
1980c10
Re: 350 cam
February 23, 2012, 09:10:38 pm »
Valves tend to float over 4k rpms with stock springs, so a valve spring upgrade would be helpful.
454Man
Why Race?
Re: 350 cam
February 23, 2012, 09:16:33 pm »
Thanks for the heads up. Can can I use the timing cover and distributor from the 305?
4
350 cam
