Author Topic: What Transmission and Tansfer Case do I have???  (Read 31426 times)
Offline Bobs85PU
« on: March 14, 2012, 06:35:06 am »
Recently, I obtained a 1980, 3/4T 4x4.
This is only the second Chevy Pickup I've owned, that I'm going to have to "build" back to highway condition.
I viewed a number of posts about transmission and Transfer Cases and am totally confused...I have no idea what components are present in my truck's drive line...Other than it has a manual floor shift transmission and manual transfer case...It also has locking hubs.
As this vehicle has sat unused for a number of years, I want to go through the drive line and replace all gaskets and seals, as it has been my experience that once I start driving the truck, every gasket and seal will start leaking...besides, I'd like to ensure the components are usable, or in need of a rebuild.
Right now, I feel I'm in over my head, but with the help of a year specific Service Manual and help from members of this website, I'll overcome my ignorance and the learning curve, and have a dependable vehicle when I'm done.
Here's a picture of the Transmission and Transfer Case:
By the by, the original cab was burned in an electrical fire...So, I have a real do-it-yourself project on my hands!!! :-\
« Last Edit: March 14, 2012, 06:36:46 am by Bobs85PU »
Offline ehjorten
Re: What Transmission and Tansfer Case do I have???
« Reply #1 on: March 14, 2012, 09:14:58 am »
The transmission is a Muncie SM465.  It is a 4 speed with a compound first gear (gearing: 6.55, 3.58, 1.70, 1.00, 6.09R).  First gear is unsynchronized, but the rest do have synchros.
The transfer case looks to be a NP 205 due to what looks like the 'figure 8' adapter pattern.
-Erik-
Offline Engineer
« Reply #2 on: March 14, 2012, 06:48:21 pm »
Yup. SM465/NP205.
The strongest combo available for our squarebodys. :)
Should have a GM Corporate 10-bolt front axle, and the GM Corporate 14-bolt, 10.5", full float rear axle.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Jason S
« Reply #3 on: March 14, 2012, 09:03:28 pm »
Welcome to the site.
The SM465/NP205 you have are a very stout combination.
Offline Bobs85PU
« Reply #4 on: March 15, 2012, 08:43:02 am »
Yup. SM465/NP205.
It looks like that's what I have!!! Here's some pics:
Front manual hubs:
10-bolt front axle:
Rear axle end view:
Rear axle:
Another view of the Transfer Case:
Offline heavychevy91
  • '86 Chevy K20
« Reply #5 on: March 16, 2012, 05:16:23 pm »
Front axle is a Dana 44 with the factory Dana-Spicer locking hubs, Rear is a Corp. 14 Full Floater. If I had to guess you probably have 4.11 gears. As said you also have a NP205 transfer case and SM465 transmission. IIRC the transfer case is 1979-80 vintage due to the slip yoke of the 205. Someone will chime in if I am wrong.
Offline Engineer
« Reply #6 on: March 16, 2012, 06:01:37 pm »
That's a 10-bolt F/A. No doubt about it.
  • '86 Chevy K20
« Reply #7 on: March 16, 2012, 08:02:27 pm »
Darn i posted too quick without looking. So should an 80 K20 have had a 44 and maybe someone swapped it out?
« Reply #8 on: March 17, 2012, 02:06:30 am »
i think 80 was the changing year where the early trucks got 44s while the new trucks got 10s
Offline Engineer
« Reply #9 on: March 17, 2012, 05:24:25 pm »
If your '80 has a D44 then it was a swap.
Up to 1978, 1/2, 3/4 trucks had the D44. 1979~1987(91) had the 10-bolt.
Additionally, all 1980 4x4 trucks had the NP205, with spicer lockouts.
« Reply #10 on: March 18, 2012, 01:44:09 am »
lol i was off by a couple years but it could still be around in other stock setups
Offline junkman.
« Reply #11 on: April 01, 2012, 04:02:45 pm »
Its a good drive train not the best or worst  we don't know what gear ratio you have but no problem using 33 inch tires and with 10 bolt front axle 36 inch max  if you run an open diff
maybe 38's  light foot
I have a friend that runs 38's with 1/2 tone axles and when it brakes he pays to have it fixed
