Author Topic: rear sway bar build  (Read 9191 times)
Offline skinu
rear sway bar build
« on: March 29, 2012, 11:32:04 am »
Anyone use a wrecking yard rear sway bar on a lowered 84 c10 1/2,if so what worked for ya,
Re: rear sway bar build
« Reply #2 on: March 29, 2012, 12:45:21 pm »
I would suggest buying a universal kit over junkyard though. Why do you need a rear sway bar anyway? Did you remove leafs? Axle flip?
Offline skinu
« Reply #3 on: April 03, 2012, 10:57:50 am »
i did remove 2 leafs but i get severe lean thru turns and watching it turn the front stays fairly level while the back torques over,in wet or slightly slick times its scary,the truck is a long bed with 2-4 drop and uses 275/60/15 bf's, here in montana the roads go from long staight  to steep winding with 100 plus winds,just want a more stable feel
« Reply #4 on: April 03, 2012, 07:54:22 pm »
Did you replace the shocks?
Offline Da67goatman
  • Burban
<Pitcrew>
