Author Topic: Bad coil our more than that?  (Read 6270 times)
Offline colton hicks
« on: April 01, 2012, 05:37:32 pm »
Is there anything that.could have caused this? Or is it one of those things that just wear out over time? I plan on checking my ignition systems for wear tommorow but is there anything in particular I should look for that caused my coil top blow?
1980 Chevrolet C10 Silverado, 350 with 4 barrel carter quad recently rebuilt, new shocks, ball joints, bed rails,  steering gearbox, gauge cluster and mirrors. First build/love affair. I recently upgraded from a shadetree to a concrete driveway. Lol
Offline 454Man
  • Why Race?
Re: Bad coil our more than that?
« Reply #1 on: April 01, 2012, 06:11:26 pm »
Not being grounded can cause that. Couple questions come to mind. Does the engine have ground straps from the engine to the body or frame? Also was there a ground strap/ metal peice going from one screw to the center connection of the plug?
« Reply #2 on: April 01, 2012, 08:28:21 pm »
The coil was grounded to the frame around itself. And it was loose I thought that could have been the problem myself but I wasnt sure. The guy that owned it before me had stripped the screw that grounded it out so I had to replace the cap also but thanks you confirmed my suspicions.
« Reply #3 on: April 03, 2012, 05:51:59 am »
     Besides grounding (you should really fix that by the way), coils can "blow" up by under/over charging, it would be great idea to check your system out when you get to the point of installing a new one.
