My new balancer aint got no
Topic: My new balancer aint got no (Read 10357 times)
Skunksmash
April 04, 2012, 08:05:22 pm »
My new harmonic balancer aint got no numbers! My old balancer had the rubber coming out the back of it, so I replaced it with a new one made by Lunati. They have a half decent reputation and I got it on sale for $89 cause the site was clearancing them. Regularly $200.
So anyway, this thing aint got no numbers! How am I supposed to tell where 10 degrees before top dead center is, with no numbers? I know this is a Ford but I also know you guys are good and if anyone knows this its yall. Its on my 95 mustang GT. My other pride and joy besides my 87 R10. I was hoping that by looking at the pics, somebody would know what line would be the zero line, and which way would be before TDC, and which way would be after TDC. Then maybe I can pinpoint where 10 degress BTDC is.
454Man
Why Race?
Re: My new balancer aint got no
April 04, 2012, 08:08:31 pm »
Idk get some timing tape with# s and just lay it on. I'm sure someone else will chime in:) good luck
Skunksmash
April 04, 2012, 08:10:13 pm »
I wouldn't even know where to stick the timing tape.
454Man
Why Race?
April 04, 2012, 08:38:51 pm »
Is ther not a single line on it at all? If not id call the manufactur and see what they suggest
Skunksmash
April 04, 2012, 08:56:16 pm »
Yeah as you can see in the pics there are plenty of lines. Just no numbers.
454Man
Why Race?
April 04, 2012, 08:57:59 pm »
Oh wow I thought that's the old one.get the tape and line it up with the first mark in rotation
Once you have the tape it will be obvious
Last Edit: April 04, 2012, 09:02:41 pm by 454Man
Skunksmash
April 04, 2012, 10:01:27 pm »
If you look at pic 3, you can see that there is 1 mark out there all by itself. All lonely looking. Could that be the first mark? Or do you mean where all the lines start, that are clustered together? I have no idea why that one line is out there all by itself. But there are others like it on the other side too.
454Man
Why Race?
April 04, 2012, 10:18:43 pm »
That line just may be tdc. The lines on the tape should match all the lines clustered together
454Man
Why Race?
April 04, 2012, 10:20:48 pm »
http://m.summitracing.com/parts/SUM-163594
Look at this tape. Can you see the resembleance between the marks on your balancer?
Avidyn
April 05, 2012, 01:14:16 am »
Was that balancer new or used that you put on? Summit sells new ones for $80.
Skunksmash
April 05, 2012, 03:13:36 am »
That one was all new and shiny. Then the rust came. I would have coated it in some kind of.. clearcoat if I had known it was going to turn into a rust farm. Here is the balancer:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&item=380410267239&nma=true&rt=nc&si=G2c%252BXSOY9K4MHbkYiFUt3fWD1EA%253D&orig_cvip=true&rt=nc
Oh and I bought that timing tape. Maybe I'll get lucky with it.
Last Edit: April 05, 2012, 03:17:19 am by Skunksmash
bake74
April 05, 2012, 06:53:23 am »
Unfortunately I do not build engines, but I would assume if you could ask someone around where you live that does build engines they would have a right answer for you.
74 k10, 77k10 Tom
1979C20
Kyle Taulton.
April 05, 2012, 01:32:16 pm »
Maybe that's why they were on clearance. If it has lines on it, bring it to tdc and then you will know which line is TDC, then ge a timing tape and put the 0 on that line. Idk how ford works, but I'm sure it goes off of number 1 cylinder being a TDC like chevys.
Skunksmash
April 05, 2012, 05:13:52 pm »
Yeah it does. Do I need to do anything to the distributor at all? Or can I just get the number one piston up to top dead center, and then look at the balancer to see what line is at the timing mark? By timing mark, I mean that thing that you line up the balancer with when you are using a timing light to set the timing. That would be 0 right?
jaredts
April 05, 2012, 06:14:53 pm »
Measure the o.d. of the balancer carefully. Multiply by pi (3.14). That's the circumference of the balancer. Put a scale or calipers between two of the marks and get that distance as accurately as you can. Divide the circumference by the distance between marks. Divide 360 by that number and that will tell you how many degrees the marks are apart.
Use a straw as a feeler through the spark plug hole of #1 and bump the starter to check that the long line is tdc for #1 as it should be. Advanced should be the pointer pointing at a mark on the ccw side of the tdc line looking from the front.
I count 26 lines on each grid and they appear to cover a little more than 45 degrees of the balancer. I think they're 2 degrees apart which is common.
