Author Topic: Shifter removal (yes I've searched) :)  (Read 22764 times)
Offline TimberwolfFXDL
« on: April 06, 2012, 07:21:00 am »
Hi all!  I've searched this and other forums, and the consensus seems to be I should be able to push down on the cap, give a quarter turn, and the whole shebang comes out.  Problem is, while I can compress it just fine, there's no turning no matter how far I push.
I'm 210lbs, and with all the weight I can put on my two thumbs to compress the spring, there's still no turning it.  It's not stuck, it moves freely, fwiw.
Suggestions?
Also, my build sheet says 3 speed manual transmission (this is an I6 base model truck) but it's definitely a 4 speed.  The shift knob says L in the lower left of the standard H pattern, with reverse on the far right (past the H) and down.  And even though it says L on the shift knob, it doesn't feel like a granny low at all.  Feels like a normal first gear.  What transmission is this and what should it have been originally?
« Last Edit: April 06, 2012, 07:26:26 am by TimberwolfFXDL »
Re: Shifter removal (yes I've searched) :)
« Reply #1 on: April 06, 2012, 07:42:01 am »
Judging from the floor it more than likely was a 3 speed on the column.  It appears you have the SM465 transmission.  Low probably doesn't feel like low probably due to a tall gear in back 2.73 or 2.56.  Sometimes there is crud built up in the top cap and you have to push down and turn with a large pair of channelocks so the teeth in the pliers give you grip.
« Reply #2 on: April 06, 2012, 08:02:03 am »
Not sure what to grip though?  it's a dome, there's no real edges to grab, especially after I have to push down on it
« Reply #3 on: April 06, 2012, 08:07:38 am »
The pliers teeth is gripping the dome, better twist traction
Offline thirsty
    • Suitor's Garage
« Reply #4 on: April 06, 2012, 08:55:19 am »
I use a large washer that I have to push down and turn it. It came in the packaging for a magnetic cb antenna. Works perfect every time on a sm465.
It looks like you have it started some in the pic. Maybe you are pushing down so hard it's making it hard to turn?
« Reply #5 on: April 06, 2012, 09:00:44 am »
How far do you push?  That's one thing I've never really seen made clear.  I've tried from about 1/8" to fully bottoming it out (or so it feels)
Offline thirsty
    • Suitor's Garage
« Reply #6 on: April 06, 2012, 09:57:31 am »
This is what you are dealing with inside there.
This is the washer that I use for equal pressure.
Hope this helps you out.
« Reply #7 on: April 06, 2012, 11:42:21 am »
That does help!  Thanks a lot :)
I will give it a shot tonight and see what happens
Offline Grim 82
« Reply #8 on: April 06, 2012, 01:42:02 pm »
Put it in neutral before you remove it. That will help when you go to put it back in.
« Reply #9 on: April 06, 2012, 01:50:26 pm »
It's not going back in (700r4 is replacing it and this will go to the classified instead) but I will leave it in neutral anyway for the next guy :)
« Reply #10 on: April 06, 2012, 03:07:37 pm »
Found a pile of mig wire spools in the scrap bin at work.  Gonna take one home with me and see if it will work in a similar manner to the giant washer shown above...
There was a enough friction between the washer and cap to just give it a twist once you pressed it down?  heck, I'll give it a light tack of JB Weld that I can clean off later if need be!
« Reply #11 on: April 06, 2012, 07:21:32 pm »
well, not that you guys care :) , but nothing worked.
as a last resort I grabbed a semi sharp wood chisel and laid a corner on the cap.  Tapped it with the hammer and after a couple dozen taps it came free.  Shook the shift handle a few times and it raised up and out.
That frees things up for the trans swap tomorrow!
Offline thirsty
    • Suitor's Garage
« Reply #12 on: April 07, 2012, 09:25:55 am »
Not true...we always care and want to have things work out. ;)
Glad you got it out so you can move on. Something must have been buggered up in there, they usually aren't that much trouble to get out.
« Reply #13 on: April 07, 2012, 09:52:38 am »
Penetrating oil and work it up and down a few times, a few soft blows, put a rag over it and turn. Glad you got it out
« Reply #14 on: April 07, 2012, 10:13:57 am »
Thanks all.  Working on getting the trans out this morning.  Gotta go find a transmission jack.  No way I can just slide this sucker out on my own.
Found out something else I didn't know... going to need a new driveshaft for the swap too.  Didn't realize they were different until I went to unbolt it.
