Author Topic: Ignition power wire?  (Read 10981 times)
Offline 454Man
  • Why Race?
« on: April 15, 2012, 04:50:36 pm »
Does anyone know what wire on the steering column gets power when the ignition key its in its complete forward position? Got the other column on and I still can't start the truck with the key. What gives?
Re: Ignition power wire?
« Reply #1 on: April 15, 2012, 05:01:36 pm »
Check to make sure the neutral safety switch works and is connected.
Offline 454Man
  • Why Race?
« Reply #2 on: April 15, 2012, 06:28:57 pm »
Ok. I left the column down when I tested the key. The neutral safety switch is connected and it clicks. Is there another way to test it?
Offline 454Man
  • Why Race?
« Reply #3 on: April 15, 2012, 06:38:29 pm »
Maybe it needs to be adjusted. Ill check
« Reply #4 on: April 15, 2012, 08:32:06 pm »
With an Ohm meter you should have a closed connection in both Park and Neutral.  It is open all other times.  To test if it is bad, jump the two wire plug with a paper clip...
Offline 454Man
  • Why Race?
« Reply #5 on: April 15, 2012, 08:56:33 pm »
Ok will do
Offline 454Man
  • Why Race?
« Reply #6 on: April 16, 2012, 09:18:09 pm »
Ok so just did the checks you suggested with the ohm meter and the paper clip. The switch has resistance but the paper clip trick didn't do anything:( guess I'm chasing electrical grimblins
Offline 454Man
  • Why Race?
« Reply #7 on: April 16, 2012, 09:29:41 pm »
I'm going to ohm check the fuseable links at the starter and see if they are good
Offline 454Man
  • Why Race?
« Reply #8 on: April 16, 2012, 09:38:42 pm »
Fuse links are good
Offline 454Man
  • Why Race?
« Reply #9 on: April 16, 2012, 09:42:58 pm »
If either of the yellow or purple wire are supposed to have voltage when the key is turned foward... they don't. Hope this helps.
Offline 454Man
  • Why Race?
« Reply #10 on: April 17, 2012, 08:47:32 am »
Got it:) it was the ( I think) its called) ignition start switch that needed to be adjusted. I took the old one off my other column when I got this one and didn't adjust it. Got it fixed! Thanks!
