Author Topic: 2 inch DJM lowering shackles don't fit  (Read 27990 times)
Offline Fairlane514
« on: April 20, 2012, 08:06:48 pm »
I installed the DJM 2 inch lowering shackles on a 85 short bed 2wd. The top of the shackle hits the bed crossmember just above it and prevents it from moving. I called DJM and they said I will have to notch the crossmember.
Has anyone had better luck with a different brand?
Thanks!
Offline Jarrett1967
Re: 2 inch DJM lowering shackles don't fit
« Reply #1 on: April 20, 2012, 09:00:46 pm »
I used Eibach and had to notch the bed cross-member as well.  I don't think there's anyway around it if you want to lower the rear and have good suspension travel.
1975 Chevy Custom Deluxe C10
Offline HAULIN IT
« Reply #2 on: April 20, 2012, 09:35:20 pm »
To use a 2" drop shackle, your going to have to notch the bed rail. No other way around it. There just isn't room to get that much in a shackle without "making" room for it. Lorne
Offline Fairlane514
« Reply #3 on: April 20, 2012, 11:05:43 pm »
Ok, thanks for your help.......gettin out the cutting wheel
« Reply #4 on: April 21, 2012, 09:29:12 am »
When I had them on my 74 it cleared the bed floor but I did not use DJM.
« Reply #5 on: May 21, 2012, 07:42:46 pm »
Yours was a Long Bed Vile,  Not an issue on longbeds.
Offline sbx22
  • 1974 1/2 ton 350 sbc
« Reply #6 on: May 22, 2012, 12:30:28 am »
My 74 long bed, I lowered with DJM 2". I cut the bedframe before I even put the shackle on due to recommendations on here, so I will never know if I had to cut it or not. Pretty quick to cut though if you have a wheel, 5-10 min maybe?
« Reply #7 on: May 22, 2012, 05:24:58 am »
Not an issue on stepsides either than I take it?
« Reply #8 on: May 22, 2012, 09:52:21 am »
pretty sure Stepsides are ok also.
Offline got2haul
« Reply #9 on: May 24, 2012, 02:13:41 pm »
I had to notch the bed rail to clear Belltech shackles on my stepside.
Under-bed rail notch for clearance above shackle:
Image of the distance that the shackles rise above the top of the frame rails (directly under that notch):
« Last Edit: May 24, 2012, 02:16:02 pm by got2haul »
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
« Reply #10 on: June 13, 2012, 04:07:16 pm »
got2haul, yours is a 56" HD leaf setup...  They need clearancing
