Author Topic: 31in tires on a 2wd  (Read 49999 times)
Offline Elpresidente
31in tires on a 2wd
« on: April 22, 2012, 07:28:15 pm »
Currently have stock 235/75R15, considering a set of 31x10.5x15's. Is there any issue with the front tires rubbing if the truck is at stock height? I know the backs have tons of room.
Also if anyone has pictures of a 2wd w/ 31's that would be cool to see how mine might look. its an '82 with a long box.
'82 Chev Scottsdale
Proud to be Canadian \m/
Offline Da67goatman
  • Burban
Re: 31in tires on a 2wd
« Reply #1 on: April 22, 2012, 07:47:36 pm »
Even with 250k miles on half ton springs, they fit fine on 15x7 rally wheels.  Here's a pic of the front on a suburban.
<Pitcrew>
Offline csdineley
« Reply #2 on: April 22, 2012, 07:57:38 pm »
Here's mine, not quite what you asked for. But mine is a 3/4 ton with 245/75r16 tires. Which if I did it right would be around 30X9.6-16. And stock ride height.
1987 V20 Custom Deluxe, Vortec Headed 350, SM465,Np205 14Bff 4.10
Offline c10kid13
« Reply #3 on: May 31, 2012, 07:21:43 pm »
i dont have a good picture but my brother recently purchased an 86 gmc c1500. it is stock height with 31x10.50s on the stock rally wheel and they do not rub at all
Offline 454Man
  • Why Race?
« Reply #4 on: May 31, 2012, 09:17:29 pm »
I have a 82 long wheel base with 31s on 15x8 wheels ill snap some tomorrow morning. :)
Offline sbx22
  • 1974 1/2 ton 350 sbc
« Reply #5 on: May 31, 2012, 09:58:11 pm »
I had 31x10.5x15's on back in the day. See pic.
No rubbing, no issues.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #6 on: May 31, 2012, 11:20:23 pm »
You can fit 32x11.50s without a problem, so 31's aren't any problem either
HEre's my 77 with 31's
Offline 1987ScottsdaleGuy
« Reply #7 on: September 07, 2012, 12:11:47 pm »
i have a 1987 half ton 2wd scottsdale and 31's do NOT fit, even when i took the running boards off.  Look on your door that sticker probably says 225/75/r15 so getting a nice set of 235/75/r15 with 100% will look great and is even a hair bigger so you should be happy with that.
After reading this post i went out and bought 4 31's off a guy i knew and when i got home they didnt fit... Well they "fit" , but were way too big in the front. Not a good idea man.
Offline Da67goatman
  • Burban
« Reply #8 on: September 07, 2012, 01:51:39 pm »
That means your truck has something amuck.  Could be your springs are shot/broken, shocks, frame damage ect, but something is not right, they do indeed fit on a half ton.
<Pitcrew>
  • Z62 ON-ROAD
« Reply #9 on: September 07, 2012, 08:23:35 pm »
1987ScottsdaleGuy:  Maybe the fromt springs are sagging or the suspensions off from front to back.  I put them on my 87, and it was the lightest duty truck you could get  and the lowest stock height, and 32's fit fine.  On that same 87, 33's up front only scrubbed when turning at an angle like fron a driveway going down hill to the roadway.  Normal flat driving, 33's fit alright.
Also, could be your fenders / cab are out of square from the frame.  I've seen that happen before.
« Reply #10 on: September 12, 2012, 12:40:13 pm »
More than likely my springs are just worn out and i need new ones
Offline werewolfx13
« Reply #11 on: September 30, 2012, 10:50:40 pm »
I've got 31 x 10.50  Cooper Discoverer STT on 15x9" wheels and they fit fine on my '83 c10, and the drivers fender is still crumpled in from the front a bit from a wreck it was in prior to when I bought it.
Chris
'83 Chevy c10 Silverado SWB
Offline 1979C20
  • Kyle Taulton.
« Reply #12 on: October 01, 2012, 05:47:31 am »
My c20 clears 285/75/r16 (32.8 x 11.2) with no rubs or problems. Even offroad. Allthough the taller tires make my front suspension bottom out on bumpstops over washboard terrain. And my suburban clears 315/75\r16's (34.6 x 12.4) with a 4 inch lift with no rubs or problems even when fully flexed.
Offline lindsdavid
« Reply #13 on: October 04, 2012, 10:39:01 pm »
32x11.5xr15 on 15x9 Ar rims
« Reply #14 on: October 08, 2012, 09:10:23 am »
Looks like the fronts raised a bit from stock height?
'82 Chev Scottsdale
