Author Topic: Pressure switch?  (Read 3646 times)
Offline Fairlane514
Pressure switch?
« on: April 23, 2012, 08:21:45 pm »
Just above the oil filter on the adaptor is a pressure switch with two male spade terminals. The plug that plugs into it is making contact with my newly installed shorty header.
Is this a low pressure warning light? Can I unplug and then loop it?
 Its on a 84 with a Goodwrench 350.
Re: Pressure switch?
« Reply #1 on: April 24, 2012, 07:37:11 pm »
     I am not positive, but is that your oil sending unit for the gauge inside the cab.
« Reply #2 on: April 24, 2012, 07:49:50 pm »
If it has pink and blue wires connected it might be for the electric choke heater on the carb.
Edit:
Can you use an angled fitting to gain needed clearance, then use heat reflective loom around the wires, connector and switch?  Or, maybe, relocate the switch next to the distributor at the back of the intake manifold and reroute the wiring.
« Last Edit: April 24, 2012, 07:59:39 pm by bd »
« Reply #3 on: April 24, 2012, 08:39:16 pm »
Two wire is the switch which in 84 was used for the choke circuit. To BD you listem mmmm
« Reply #4 on: April 25, 2012, 12:36:51 am »
LOL - Dang, Vile!  I never noticed the Family resemblance, before....   ;D
Much it explains!
« Reply #5 on: April 25, 2012, 08:59:29 pm »
 :P
