Author Topic: Which color rtv adheirs to rubber gaskets the best  (Read 20735 times)
Offline 454Man
  • Why Race?
« on: April 27, 2012, 11:14:58 am »
I have a little leakage at the front and back of my intake. I'm gonna put the rubber seals on and what to know what y'all think about the best sealant to use with the rubber end gaskets
Offline codyC10kid
Re: Which color rtv adheirs to rubber gaskets the best
« Reply #1 on: April 27, 2012, 11:36:19 am »
Your intake gasket????me i would just buy a new intake gasket set,i dont use silocone on intake gaskets...i use blue on my valve cover oil pan water pump,stuff like that...has yet to leak
Offline 454Man
  • Why Race?
« Reply #2 on: April 27, 2012, 12:07:49 pm »
Not the gaskets for the intake just the black rubber end seals
Offline codyC10kid
« Reply #3 on: April 27, 2012, 12:10:03 pm »
What motor? what seals valvle cover?,rear main? i have no idea..OH you mean the BOTOM of the intake and the top of the block right
« Reply #4 on: April 27, 2012, 12:13:22 pm »
I was told to never use RTV on those end gaskets by my mechanic buddy just a dab at the place where the intake gasket goes over the black seal in the corners.  He also suggests only use RTV on the front oil pan instead of the gasket.  I have only done a few and have never had a leak following his advice.  My $.02
« Last Edit: April 27, 2012, 12:15:38 pm by zieg85 »
Offline 454Man
  • Why Race?
Re: Re: Which color rtv adheirs to rubber gaskets the best
« Reply #5 on: April 27, 2012, 12:15:07 pm »
350 and yes
Offline 454Man
  • Why Race?
« Reply #6 on: April 27, 2012, 12:17:18 pm »
I was told to never use RTV on those end gaskets by my mechanic buddy.  He also suggests only use RTV on the front oil pan instead of the gasket.  I have only done a few and have never had a leak following his advice.  My $.02
ok stop you just used them gaskets by themselves and no rtv? My engineguy dias to not use them gaskets....like I was going to, now I have leaks
Offline codyC10kid
« Reply #7 on: April 27, 2012, 12:19:56 pm »
My motor,chevy 350 has just a thick gob of rtv right in that area...and one of my magazines show them building a motor and they said not to use the rubber gasket just a thick gob of silocone
« Reply #8 on: April 27, 2012, 12:20:13 pm »
     There are defiantly different views on using RTV on the intake.  Some say never, some say you can not get certain intakes to stop leaking if you do not use some.
     I am in the same lines as the others here, I have not had problems with intakes sealing with just gaskets before.  But I make sure the heads, the block ends, and the intake are flat and have a good clean, smooth surface to mate together and that the intakes are torqued down properly.
« Reply #9 on: April 27, 2012, 12:21:40 pm »
The end gaskets on top of the block go down first.  Put a dab of RTV on where the intake(metal) gasket go over the rubber ones.
Offline 454Man
  • Why Race?
« Reply #10 on: April 27, 2012, 12:28:50 pm »
yeah that thick bead didn't work for me.I'm gonna try just gaskets and a dab in the corners
Offline 454Man
  • Why Race?
« Reply #11 on: April 27, 2012, 12:32:53 pm »
What in gonna do thus time is put everyting in place then see if there is a gap between the intake an gaskets. If there a gap then I'll use the rtv in the middle aswell
« Last Edit: April 27, 2012, 12:40:35 pm by 454Man »
« Reply #12 on: April 27, 2012, 12:57:58 pm »
Or..... wait to have Vile and/or Blazin reply as I personally wouldn't be afraid of their advice...
Offline 454Man
  • Why Race?
« Reply #13 on: April 27, 2012, 01:18:27 pm »
True...I'm in no rush...just trying to get everyones opinions, besides this will be the third time I've takin off the intake (for various reasons):) and want to make it my last:)
« Last Edit: April 27, 2012, 01:20:34 pm by 454Man »
« Reply #14 on: April 27, 2012, 08:11:24 pm »
     Smart man.   ;D
