Interior & Equipment
Interior / sound system pics anyone?
Topic: Interior / sound system pics anyone? (Read 18584 times)
travisr1988
May 04, 2012, 03:32:46 pm »
Looking for pictures of nice interiors and sound systems to give me ideas
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
bake74
Re: Interior / sound system pics anyone?
May 09, 2012, 07:19:30 pm »
Have you browsed through the member ride section here ?
74 k10, 77k10 Tom
codyC10kid
May 10, 2012, 12:17:15 am »
Im starting to do a sound system on my 77 K10... Link>
http://forum.73-87chevytrucks.com/smforum/index.php/topic,23677.0.html
Im not done and i havent been woring on it....Im building a 350 for it right now and busy with work
travisr1988
May 10, 2012, 01:25:18 pm »
I have browsed through and after a few hours decided it would be less tedious to get a post started specifically for it
SUX2BU99
May 12, 2012, 01:52:42 am »
I've got some pics here on my sounddomain page
http://www.cardomain.com/id/sux2bu99
I've got one for my truck but then under my Avenger I also have another one for my truck that shows more of my previous systems and my other vehicles systems over the years.
74GMC
May 12, 2012, 06:41:12 am »
I didn't want to cut holes in the dash or doors so I installed all the stereo stuff behind the seat. Still need to clean up the wires, drill holes in the MDF plywood to run the wires through.
"Nothing Beats a Chev"
travisr1988
May 16, 2012, 03:41:13 pm »
that looks good 74gmc, where's the radio though?
travisr1988
May 16, 2012, 04:08:40 pm »
Ok, so here's my current setup. the 4x6s just replaced the ancient speakers in those boxes originally, left them where they were and added 6x9s in the cab corners, all new wiring going to the jvc headunit on the cieling...speakers are sony 4ways. all of the speakers and the head unit were salvaged from my s10 blazer after I rolled it...as well as 2 10" kenwoods which will be added eventually.
74GMC
May 20, 2012, 12:29:29 pm »
Thanks, the radio is the only thing that I have mounted up front.
pholliday1
1990 V3500 Crew Cab
May 21, 2012, 10:18:56 am »
74 gmc if its not to much to ask can i see a couple diff. angles of your speaker setup andcan i get details on your sub size, speaker layout, etc more info the better as i am starting this project now i like the layout of your setup does your seat go all the way back?
74GMC
May 21, 2012, 01:58:17 pm »
Sure, I'll get you some pics as soon as I can. I believe the seat goes all the way back but maybe one notch up. I'll get some info together shortly.
74GMC
May 30, 2012, 06:51:05 pm »
Sorry for the late reply, been gone with work. So the seat is one notch from the farthest back, I'm 6' 2" and I still have room with this set up. The subs are 2 10" with 6" components mounted roughly on a 45. The amps, component speakers are mounted on 3/4 MDF, easy to work with and looks good. I used some metal braces that I bent into a L shape to hold the MDF in place, very solid and worked nicely. Like I said before I plan on drilling holes in the MDF and running the wirs behind to clean it up. Also plan on making a cap on top of the corner speakers to seal it all in. This set up does sound really good, I'm happy with it, and best of all no holes in the doors.
Mike85Silverado
Under Construction
October 27, 2012, 01:04:05 am »
Where did you get that dash kit for your CD player? Is it hard to remove old bracket and put that new plastic stuff in there?
N-I-4-N-I
1979C20
Kyle Taulton.
October 27, 2012, 04:14:55 am »
My stereo build is here. My seat is all of the way back and clears the cone of the subs by a half an inch. I need to get a bigger amp.
http://forum.73-87chevytrucks.com/smforum/index.php/topic,20413.msg166249.html#msg166249
